TL:DR: The TeamSpeak UI needs an indicator as to what settings are being synced via myTS and which ones are not.
Situation:
My TS appeared drastically different on two clients, with a whole UI block for the chat history missing.
Only after research I found out that a setting under: “Chats > Use Chat History” was not applied on one client, but it was applied on the other.
Since myTS syncs some settings, but obviously not all of them, an indicator would is required telling the user which ones are being synced or not.
A suggestion would be to either
A) add a small “myTS” logo behind settings that sync or
B) put all synced settings under a myTS tab in the options.
I don’t think client settings are saved at all, so its not really needed. MyTs syncs only your bookmarks, contatcs and group chats and badges
In the old TS3 of course that was true. You could do it by copying C:\Users%\AppData\Roaming\TS3Client to a new machine but that was about it
In TS6 however, that now requires a myTS account setup and login, I believe it’s the way to go.
Not even identities can’t be exported anymore - we’re way more dependent on cloud sync with this version (even if that will become an option again in the future).
So I’d still suggest that would be a decent option for users that want to use TS6 across multiple clients / platforms. It’s just what most users expect and frankly, without help from teamspeak staff, I would have never found out why my two clients looked so different for example.
