Add Permission settings for channels
hello teamspeak.
in the next beta you could include in TS5 the channel configuration options that I present to you in the following photo because this option is very important in the channel configuration. thank you
and also the icons, we can no longer put them with ts5 whether to load them on the server or to assign them to channels it would be good to add that to us. then also be able to assign them also to the different server group and channels
I vouch for this, really annoying to switch back to ts3 just because you want to properly setup a channel
How the Hell do I change channel permissions on the new client? such as Join power and so on for specific channels
That is not yet implemented into the new client. You’ll need to use TS3 to change the channel permissions.
