Hi everyone,
I’d like to share a small open-source bot I put together for TeamSpeak 6:
TS6 AFK Bot. It automatically moves idle users to a separate AFK channel
and works entirely over SSH ServerQuery — no client-side plugins required.
What it does
- Connects to the TS6 ServerQuery over SSH (default port 10022).
- Moves users to the AFK channel after a configurable idle threshold.
- Optionally sends a poke message before moving.
- Supports exclusions by client_unique_identifier and by channel.
- Automatically reconnects if the SSH connection drops.
- Graceful shutdown on Ctrl+C / SIGTERM in under 0.5 seconds.
- Uses a single
clientlist -uid -timesquery per tick instead of N+1
clientinfocalls — matters when you have a few dozen users online.
Requirements
- Python 3.10+
- paramiko >= 3.4
- On the TS6 server: SSH ServerQuery enabled (port 10022 by default) and a
query account withb_client_move_powerandi_client_poke_power.
Installation
The repo ships with an automated installer for Linux (install.py) that
takes care of everything: checks dependencies, creates a system user, clones
the repo, sets up a venv, generates config.json and a hardened systemd
unit, then starts the service.
sudo python3 install.py
It will ask a few questions (server address, ServerQuery port, query login
and password, virtual server id, AFK channel id, etc.). Most fields have
sensible defaults — just hit Enter.
There’s also a non-interactive mode for automation:
sudo python3 install.py --non-interactive \
--host ts.example.com \
--query-port 10022 \
--username bot \
--password 'SuperSecret' \
--virtual-server-id 1 \
--afk-channel-id 12 \
--timeout-seconds 300 \
--check-interval 30 \
--reconnect-delay 10 \
--poke-message 'You were moved to AFK due to inactivity.'
After installation the bot runs as a systemd service:
systemctl status ts6-afk-bot
journalctl -u ts6-afk-bot -f
Manual installation (venv + systemd unit) is also documented in the README.
Configuration
host string TS6 server address
query_port int SSH ServerQuery port (usually 10022)
username string query account login
password string query account password
virtual_server_id int sid of the virtual server (usually 1)
afk_channel_id int cid of the AFK channel
timeout_seconds int idle threshold in seconds (default 300)
check_interval int polling interval in seconds (default 30)
reconnect_delay int pause before reconnect (default 10)
poke_message string poke text; empty = don't send
exclude_uids string[] UIDs to skip
exclude_channels int[] cids to skip
For security the installer keeps the password out of config.json and
stores it in /etc/ts6-afk-bot/env (chmod 600), where it is read via
TS6_QUERY_PASSWORD.
Links
- GitHub: GitHub - Rednelss/ts6-afk-bot: Бот (TeamSpeak6) для перемещения неактивных пользователей в другой канал · GitHub
- License: MIT
Feedback
I’d love to hear whether this works on your setups, and whether there’s
interest in additional features — for example:
- Auto-creating the AFK channel if it doesn’t exist.
- Moving users back to their previous channel when they become active again.
- Web UI or Prometheus metrics for monitoring.
Bug reports and PRs are welcome. Thanks for reading!
