Audio Crackling - notifications and playback
since the latest update 6.0.0-beta5 - Foundation III. My audio output is cutoff/crackling even if the volume is set to low. I am using a Headset with 2x Audio Output devices (named Chat and Game). If i swap from the Chat to the Game output the crackling is gone.
When i put sound from another Software like music on the Chat output it works just fine.
I tried a clean install, no success here.
same problem but my crackling doesnt go away when switching to the game channel.
Hey we are not able to reproduce any audio crackling issue, can you guys give us some more informations about your devices (Soundcard, Headset) pls?
Headset is a Steelseries Arctis Pro Wireless. I also have a recording of the crackling
https://jumpshare.com/s/jEC83LAQP9987wwT0DJW
I am experiencing the same audio crackling issue with my Arctis 7 Wireless headset. The crackling specifically occurs whenever someone starts speaking, as well as during client notification sounds like muting/unmuting or joining a channel. Toggling between the game and chat profiles did not resolve it for me. The only workaround that restored normal functionality was reverting back to version 4.1
Sounds exactly like @Leg3ndAry1 recording.
same here with a arctis 7 and watching a screenshare doesn’t have any sound except a voice saying continuously error
Ok thank you guys for all the informations.
We will see what we can do here.
TID: 2601
Interesting I also got the Steelseries Arctis Pro Wireless and can confirm i got exactly the problem you have on your audio example
Same here - Steelseries Arctis 7 wireless
I also get the error anouncements
Thank you! Is it possible to disable auto-updates? Because now i have to reinstall it every time i close it just to keep it on version 4.1.
Edit: nvm figured it out
I was able to reproduce the issue with VB-Audio Virtual Audio Cable set to 1 Channel.
This should be fixed with beta5.1
When will be Beta 5.1 launched?
I have same Headset with same problems.
We’re aiming for this week, but things could change.
