Audio processing settings reset when switching tabs — TeamSpeak 6.0.0 Beta 5
Environment
  • TeamSpeak version: 6.0.0 Beta 5
  • Operating system: Windows
  • Audio interface: Arturia MiniFuse 1
  • Audio backend: Windows Audio Session (WASAPI)
  • Input device: Input 1 (MiniFuse 1)
  • Alternative input device: Mix 5/6 (MiniFuse 1)
Description
I encountered an issue where microphone audio processing settings automatically reset to their default values whenever I switch to another settings tab and return to the Audio tab.
The affected settings include:
  • Voice Activity Detection (VAD)
  • Noise suppression
  • Echo cancellation
The issue also occurs when closing and reopening the Settings window.
Reinstalling TeamSpeak and resetting the audio configuration did not resolve the issue.
Steps to Reproduce
  1. Open TeamSpeak 6.0.0 Beta 5.
  2. Navigate to Settings → Audio.
  3. Select “Input 1 (MiniFuse 1)” as the recording device.
  4. Modify the VAD, noise suppression, or echo cancellation settings.
  5. Switch to another settings tab.
  6. Return to the Audio tab.
Actual result: All modified audio processing settings revert to their default values.
Expected result: Audio processing settings should remain saved for the selected recording device.
Additional Findings
I discovered that the issue is device-specific.
When selecting “Mix 5/6 (MiniFuse 1)” as the recording device, the audio processing settings are saved correctly.
However, when selecting “Input 1 (MiniFuse 1)”, the settings consistently reset.
I investigated the TeamSpeak SQLite configuration database located at:
%APPDATA%\TeamSpeak\Default\settings.db
The json_blobs table contains an audio_settings entry.
Inside this JSON configuration, the active recording device was set to “Input 1 (MiniFuse 1)”, but the saved device-specific audio processing settings were associated with “Mix 5/6 (MiniFuse 1)”.
There was no corresponding saved processing configuration for the active “Input 1” device.
Workaround / Fix
I was able to resolve the issue by manually modifying the audio_settings JSON stored in SQLite.
Specifically, I replaced the saved recording-device profile with a profile referencing the active “Input 1 (MiniFuse 1)” device, while copying the existing audio processing settings from the “Mix 5/6” profile.
After applying this change, VAD, noise suppression, and echo cancellation settings stopped resetting when switching between settings tabs.
Suspected Cause
This suggests a possible issue with device-specific audio profile initialization, persistence, or lookup.
TeamSpeak may fail to create or correctly associate audio processing settings with certain recording devices, especially when multiple input endpoints are exposed by the same audio interface.
This is a hypothesis based on the observed configuration and successful workaround, not a confirmed root cause.
Additional Notes
Deleting the audio_settings entry and allowing TeamSpeak to regenerate it did not fix the issue.
The successful workaround required explicitly creating a saved processing profile associated with the active input device.
I hope these findings help identify and fix the issue in a future TeamSpeak 6 update.
Thank for the report.
We already fixed this several times but there seems to be another way to reproduce this issue, where the client does not save audio settings correctly.
I created a new ticket for that.
TID: 2584
I can’t seem to change Voice Activity Detection. No matter what I do it goes back to Automatic. I really need to be able to set it to Hybrid, but it won’t save the settings. Swapping to another page after changing it to Hybrid and swapping back to Audio and it’s on Automatic. And there is no visible save button anywhere.
And automatic just holds my mic open.
Whenever I start TeamSpeak, my microphone transmits continuously, even though VAD is enabled in the settings. I have to toggle VAD off and back on every time to get it working properly.
This isn’t just a visual bug, other users also see my voice indicator lit up constantly. Is there a fix for this?
That got reported several times
After starting TeamSpeak, automatic VAD does not initialize correctly and the microphone transmits continuously. Disabling and enabling VAD causes it to work normally again for the current session.
At the moment, toggling VAD after startup appears to be the only reliable workaround. As far as I remember there is currently no known permanent fix.
Are you using a regular microphone directly in TeamSpeak, or something like SteelSeries Sonar, Voicemeeter or Wave Link?
I’m asking because similar issues have been reported with virtual audio devices before.
Also, does your selected VAD mode stay the same after restarting TeamSpeak, or does it reset to Automatic?
I fixed all of this by editing the database file. You need to download the DB Browser program, use it to open the settings.db file, and then change the parameters for the selected device there. It’s possible that TeamSpeak automatically selects the priority device (for me, it was the Mix 5/6) and saves only its settings. I changed its settings, copied them, and pasted them into the main device’s settings.
I use audio cart Arturia MiniFuse 1. My friend use mic from headphones and hasn’t problem with that. mb because TS uses one microphone as the primary and didn’t save changes for another. I fix that with edit settings.db file. You need to download the DB Browser program, use it to open the settings.db file, and then change the parameters for the selected device there. It’s possible that TeamSpeak automatically selects the priority device (for me, it was the Mix 5/6) and saves only its settings. I changed its settings, copied them, and pasted them into the main device’s settings.
U can edit settings.db file and save changes for that. You need to download the DB Browser program, use it to open the settings.db file, and then change the parameters for the selected device there. It’s possible that TeamSpeak automatically selects the priority device (for me, it was the Mix 5/6) and saves only its settings. I changed its settings, copied them, and pasted them into the main device’s settings.
