i am currently trying to use the new TeamSpeak Client and when i use my Bluetooth Headphones in A2DP Mode, the TeamSpeak Client “freezes”. I can’t connect to servers and the settings are almost blank.
Current Workaround:
I connect my Headset via Cable, connect to my server, disconnect the Headphones from cable and then switch to Bluetooth A2DP.
Logs:
[0126/195713.416400:INFO:CONSOLE(1)] “Notification Settings loaded. [object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object]”, sourc
e: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195713.708622:INFO:CONSOLE(1)] “Restoring previously opened activities: [object Object]”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195713.710130:INFO:CONSOLE(1)] “Not presenting beta badge interface”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.006217:INFO:CONSOLE(1)] “analytics :: heartbeat”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.006616:INFO:CONSOLE(1)] “Connecting to default chat system”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.007575:INFO:CONSOLE(1)] “default device changed: -none- to Default”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.007871:INFO:CONSOLE(1)] “default device changed: -none- to Default”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.007990:INFO:CONSOLE(1)] “default device changed: -none- to Default”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.008135:INFO:CONSOLE(1)] “default device changed: -none- to Default”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.252453:INFO:CONSOLE(1)] “Error detail: 0 device [object Object]”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195714.263355:INFO:CONSOLE(1)] “Uncaught (in promise) #<_>”, source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195717.009884:INFO:CONSOLE(0)] “Uncaught (in promise) TypeError: Failed to fetch”, source: tsui://default/index.html#/ (0)
[0126/195723.964174:INFO:CONSOLE(1)] "Couldn’t play wave file (connected): ", source: tsui://default/main-03eef409d3baf85e1f00.js (1)
[0126/195949.630021:INFO:CONSOLE(2)] “Options props is deprecated, add sortable options directly as vue.draggable item, or use v-bind. See https://github.com/SortableJS/Vue.Draggable/blob
/master/documentation/migrate.md#options-props”, source: tsui://default/vendor-e83d5b00805814053f3f.js (2)
pool dtor
System Information:
OS: Arch Linux
Audio Server: Pulseaudio
Client Version: 5.0.0-beta38
