As the title says the connection info only supports hours, minutes and seconds for the connected time and idle time. (1) misses the 1d stamp you can see in the TS3 connection info view. (2) is sometimes out of sync with the ping for ~0.1ms
On the new ts you can see connected time also you just need to hover over connected time to get exact. The other issue with ping might be because you have better connection via the new teamspeak the old or other way around
Tnx. Will forward this to our devs. The out of sync thing depends on when you opened the info dialog.
Beta 39 will fix that issue.
One year later, I completely forgot about that report
Took some time but finally it´s fixed then
