Hey,
whenever I connect my AirPods Pro to either MacBook or PC(Windows) via Bluetooth (4.1 and 5.0 respectively) and I start the TeamSpeak 3 Client on both OS’s, the audio output quality (of all applications) is degraded drastically. When I close the TeamSpeak 3 Client there is a short break (I assume something reloads related to the audio drivers) and the quality is back to normal.
Is this issue known? As it happens on two separate machines and operating systems, I am pretty sure this can be easily reproduced with given parameters.
Tested Discord and Zoom, they work fine, no quality changes there. Pretty optimistic it’s related to the Client itself.
Thanks!
Related threads:
