Can't bind STRG for PTT since current Build
OS: CachyOS - Wayland - KDE
Since Build-Nummer: 1791901251 Build-Datum: 13.10.2026, 16:20:51
my PTT Hotkey STRG is vanished. If i try to rebind, then only STRG + another key is bindable. Please fix that. With pressing two keys i can’t play games with TeamSpeak Voice. I used STRG for PTT since about 10 years or longer.
Already tried the start parameter: --ozone-platform=x11
You might want to check out my reply here, relevant to your issue. Workaround should be keyd. But it seems we should definitely support --ozone-platform=x11 manual override mode :)
After updating from TeamSpeak 6.0.0-beta4.1 to beta5, I can no longer assign Left Alt as my push-to-talk (PTT) key.
Left Alt worked correctly in beta4.1 on the same system. In beta5, attempting to configure PTT opens KDE’s “Global Shortcuts Requested” dialog, which requires a key combination and refuses to register Left Alt by itself.
This appears to be a regression associated with the new Wayland global hotkey implementation introduced in beta5.
System Information
  • Operating System: Bazzite Linux (Fedora Atomic-based)
  • Desktop Environment: KDE Plasma
  • Display Server: Wayland
  • Installation Method: Flatpak (Flathub)
  • Flatpak Application ID: com.teamspeak.TeamSpeak
  • Working Version: 6.0.0-beta4.1
  • Affected Version: 6.0.0-beta5
  • Hardware: AMD Ryzen 9 5900X / AMD Radeon RX 7900 XTX
I suppose I can downgrade to TeamSpeak 3 until this gets resolved.
You may want to read my reply just about your post :)
Already tried GitHub - jtroo/kanata: Improve keyboard comfort and usability with advanced customization · GitHub with an config to use STRG again. As long i don’t do anything else then talking it works, but if i play a game then PTT flaps away again and again. PTT works only if i don’t do any other operation ingame.
PTT Key in TeamSpeak 6 Client is shown as STRG + Toolkey
Made the kanata.kbd posted below.
(defcfg
  process-unmapped-keys yes
  linux-dev-names-exclude (
    "Logitech G502 X PLUS"
    "Razer Razer Tartarus V2 Pro"
    "Razer Razer Tartarus V2 Pro Keyboard"
(defsrc
  lctl
  1 2 3 4 5 6 7 8 9 0 min eql
  q w e r t y u i o p lbrc rbrc
  a s d f g h j k l scln apos bksl
  102d z x c v b n m , . /
  tab spc ent bspc esc del lalt ralt lsft rsft lmet
  up down left right
(defalias
  ptt (multi lctl f13 (layer-while-held ctrlheld))
(deflayer base
  @ptt
  _ _ _ _ _ _ _ _ _ _ _ _
  _ _ _ _
(deflayer ctrlheld
  _
  (multi (release-key f13) 1) (multi (release-key f13) 2) (multi (release-key f13) 3) (multi (release-key f13) 4) (multi (release-key f13) 5) (multi (release-key f13) 6) (multi (release-key f13) 7) (multi (release-key f13) 8) (multi (release-key f13) 9) (multi (release-key f13) 0) (multi (release-key f13) min) (multi (release-key f13) eql)
  (multi (release-key f13) q) (multi (release-key f13) w) (multi (release-key f13) e) (multi (release-key f13) r) (multi (release-key f13) t) (multi (release-key f13) y) (multi (release-key f13) u) (multi (release-key f13) i) (multi (release-key f13) o) (multi (release-key f13) p) (multi (release-key f13) lbrc) (multi (release-key f13) rbrc)
  (multi (release-key f13) a) (multi (release-key f13) s) (multi (release-key f13) d) (multi (release-key f13) f) (multi (release-key f13) g) (multi (release-key f13) h) (multi (release-key f13) j) (multi (release-key f13) k) (multi (release-key f13) l) (multi (release-key f13) scln) (multi (release-key f13) apos) (multi (release-key f13) bksl)
  (multi (release-key f13) 102d) (multi (release-key f13) z) (multi (release-key f13) x) (multi (release-key f13) c) (multi (release-key f13) v) (multi (release-key f13) b) (multi (release-key f13) n) (multi (release-key f13) m) (multi (release-key f13) ,) (multi (release-key f13) .) (multi (release-key f13) /)
  (multi (release-key f13) tab) (multi (release-key f13) spc) (multi (release-key f13) ent) (multi (release-key f13) bspc) (multi (release-key f13) esc) (multi (release-key f13) del) (multi (release-key f13) lalt) (multi (release-key f13) ralt) (multi (release-key f13) lsft) (multi (release-key f13) rsft) (multi (release-key f13) lmet)
  (multi (release-key f13) up) (multi (release-key f13) down) (multi (release-key f13) left) (multi (release-key f13) right)
I had already read your previous answer. keyd is not a useful workaround for my use case. Easier to just roll back the update or use the previous version. Thanks I guess.
we’ll circle back to the x11 mode and maybe allow runtime switching.
Hi, i had the same issue on CahcyOS and fixed it with the app “downgrade”.
sudo pacman -S downgrade
sudo downgrade TeamSpeak
After this choose your version to downgrade to and press enter. I am going with version beta 4.1 and it worked for me. At the end of the downgrade dialogue the app ask you if you want to ignore future updates for the application. I strongly recommend it, als log as the bug isn’t fixed yet. Later you canb start downgrade again and remove the ignore from the app.
