They checked everything that could be the reason i have told them all these reason in this chat but im not on the list
You must be on the banlist or else you would not get the message that you are banned.
Are you sure that they’ve unbanned your Client + myTSID + IP address?
I am 99.9% that they have checked everything
Then there is 0.01 % left and your screenshot tells us, that you are still banned. As Rikku mentioned, there are several possibilities to get banned (IP, myTS, etc.). The server admin/owner can filter your ban reason „Blacklisted Member - Garry“ inside of the banlist to find the ban and delete it.
Ok thanks and i will let him know, and not the 0.01% LOL
he said he checked everything, and already removed my ban reason
Have you tried to connect to the server with another identity or without myTS?
Yes
So even if that isn’t possible, it’s certain that your IP address must still be banned.
Im certain it is off the ban list, the admin has showed me
It may work if a server admin removes your client entry from the client list.
Note: This will delete all groups, permissions, connection information, etc. of the client.
They have and it still didnt work
they have done everything and i have reset my router and nothing has changed is there a way teamspeak themselves can up the ban.
Hello the question may be silly but did they try to turn off the server and turn it back on
Yes they have, They reset it when they unbanned me
