Channel Groups
I’m thinking of creating different channel ranks (Channel Admin & Channel User). How can I make it so anyone with Channel Admin can add/remove from Channel User from anyone only in the specific channel they’re admin in?
That’s the default usage of channel groups.A channel admin can make other perople in the channel voice, operators or other channel groups!
so that a channel admin can remove a channel guest from a channel, the following must be done:
First create a “channel admin” group and a e.g. “channel guest” group. Now you have to give the channel admin rank the power “i_client_kick_from_channel_power”. The values ​​must of course be adjusted if necessary. If you give a client the channel admin group in a specific channel and another client joint in this channel, the channel admin can kick the client from the channel (if the client to be kicked has a lower “i_client_needed_kick_from_chanel_power”).
Or did you mean how it works that the channel admin rank can add / remove channel ranks in a specific channels?
I hope I could help you.
with Best regards!
