Client won't open
I am pretty sure the -safemode should have worked. The files you provided show plugins being loaded and the log ends just after the ChannelWatcher_win64.dll plugin gets loaded. I don’t have the time right now to fully check if it’s the culprit here, but I strongly believe so. So either try starting with safemode again or remove that plugin for now.
This still didn’t work. I’m not even getting a crash report this time.
Plugins can cause a crash, remove all plugins or the last ones you installed and try again.
Edit:
As @Gamer92000 said, the crash occurred after loading “ChannelWatcher_win64.dll”
Try to delete that plugin.
2023-07-30 21:34:24.261535|INFO |Plugins | |Loading plugin: ChannelWatcher_win64.dll 2023-07-30 21:34:24.428975| |KeyBindings | |Default monitoring disabled
@opZ1ca
So I don’t remember installing all these (excluding the Codewatcher, I already got rid of that one.) Just uninstall all these??
Well some of them are “official” from TeamSpeak but for testing you could just rename the plugin directory.
@opZ1ca @Gamer92000 Thank you guys for your help. I was able to restore my TS. Once again thanks for the help. Greatly appreciated!
