Hey I’ve been trying to install and get TS6 running for the last few weeks and every time i download the .msi for the TS6 beta 3.4 and get it installed it does not open when the wizard finishes and will not open from any of the desktop shortcut, start menu shortcut, or by going directly to the .exe in directory. I had installed and gotten it working before a few months back and I’m looking to switch now with the Discord ID nonsense but I had issues a few weeks back with getting it to connect, apparently that day had server issues client wide, and so i uninstalled and reinstalled that day and ever since it doesnt work anymore and I have no idea what else to do.
Can you check if the Media Feature Packs are installed?
I am not running a verision of windows 10 N im on standard windows 10 home so the media packs dont allow me to install them as they should already be set up
Can you please check for any logs or crash dumps in the corresponding folders that I’ve mentioned here:
I have both the most recent tschat.log listed below and a DMP file from the same date but i cant attach that to this post
\[2025-10-09 01:34:06.453\] \[info\] TSBindingBrowserTSChat ctor
\[2025-10-09 01:34:06.453\] \[info\] TSChat library version: 1
\[2025-10-09 01:36:04.561\] \[error\] Failed to create central matrix account
\[2025-10-09 01:37:05.216\] \[info\] update homebase: tsChatId=0
\[2025-10-09 01:37:05.216\] \[info\] Updating homebase to 0
\[2025-10-09 01:37:05.216\] \[info\] Homebase deleted, tsChatId = 0
\[2025-10-09 01:37:05.216\] \[error\] No homebase found
\[2025-10-09 01:37:05.803\] \[error\] Failed to move homebase to central: 1
\[2025-10-09 01:37:05.857\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-10-09 01:37:05.859\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-09 01:37:05.860\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-10-09 01:37:05.860\] \[error\] Failed to load save data (open C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU: The system cannot find the file specified.)
\[2025-10-09 01:37:05.890\] \[info\] Creating fresh store
\[2025-10-09 01:37:05.890\] \[info\] new crypto account on init - fresh
\[2025-10-09 01:37:05.891\] \[info\] created new group session storage
\[2025-10-09 01:37:05.906\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-10-09 01:37:06.973\] \[info\] Login successful
\[2025-10-09 01:37:07.236\] \[info\] Initial sync… nextBatch=
\[2025-10-09 01:37:07.565\] \[info\] 50 new one time keys are created
\[2025-10-09 01:37:08.294\] \[info\] Initial sync done
\[2025-10-09 01:37:08.294\] \[info\] Connect done
\[2025-10-09 01:37:08.294\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-10-09 01:37:08.313\] \[info\] start: ts_chat_id=1
\[2025-10-09 01:37:08.313\] \[info\] Starting matrix client
\[2025-10-09 01:37:08.833\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-09 01:39:05.145\] \[info\] search_local
\[2025-10-09 01:39:06.816\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-09 02:01:09.144\] \[info\] Direct rooms changed, update m.direct account data
\[2025-10-09 02:01:13.971\] \[info\] join_room ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net server_name=
\[2025-10-09 02:02:45.091\] \[info\] set_read_marker: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net message_id=$g2S0vmZzuINIHtKUF5UAau7lffK3wbJF8jiNBggvKH8
\[2025-10-09 02:02:45.111\] \[info\] scrollback ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net oldest_message_id=$sH2AB824VSLhN63T0HZRIT5JM_odvzFc3aX5brpJaKI size=50 return_code=
\[2025-10-09 02:02:45.112\] \[info\] fetch events with token=s12479777_1219189135_1000964_1863611_2228832_1_1599239_103528209_0_138208, includeReactions=true
\[2025-10-09 02:02:46.678\] \[info\] scrollback ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net oldest_message_id=$qdk6PTCRJC72zPcjEyBUIFXBUsIRW9z3QFG4zodszog size=50 return_code=
\[2025-10-09 02:02:46.678\] \[info\] fetch events with token=t2–2652201_1219189135_1000964_1863611_2228832_1_1599239_103528209_0_138208, includeReactions=true
\[2025-10-09 02:08:35.859\] \[info\] TSBindingBrowserTSChat dtor
\[2025-10-09 02:08:35.859\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-09 02:08:44.527\] \[info\] TSBindingBrowserTSChat ctor
\[2025-10-09 02:08:44.527\] \[info\] TSChat library version: 1
\[2025-10-09 02:08:47.552\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-10-09 02:08:47.554\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-09 02:08:47.554\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-10-09 02:08:47.568\] \[info\] Created store from save data, loaded transactionId=1760000562237, searchDbSerial=0
\[2025-10-09 02:08:47.569\] \[info\] Init crypto storage
\[2025-10-09 02:08:47.569\] \[info\] created new group session storage
\[2025-10-09 02:08:47.569\] \[warning\] get key request data: unexpected end of JSON input
\[2025-10-09 02:08:47.661\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-10-09 02:08:47.933\] \[info\] Initial sync… nextBatch=s12479813_1219195413_1000966_1863617_2228835_1_1599240_103528962_0_138208
\[2025-10-09 02:08:48.176\] \[info\] 1 new one time keys are created
\[2025-10-09 02:08:48.935\] \[info\] Initial sync done
\[2025-10-09 02:08:48.936\] \[info\] Connect done
\[2025-10-09 02:08:48.936\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-10-09 02:08:48.956\] \[info\] start: ts_chat_id=1
\[2025-10-09 02:08:48.956\] \[info\] Starting matrix client
\[2025-10-09 02:08:49.228\] \[error\] Failed to unmarshal contact list: invalid character ‘\\x01’ looking for beginning of value
\[2025-10-09 02:08:49.228\] \[error\] invalid character ‘\\x01’ looking for beginning of value
\[2025-10-09 02:08:49.479\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-09 02:08:51.234\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-09 02:08:54.082\] \[info\] scrollback ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net oldest_message_id=$qdk6PTCRJC72zPcjEyBUIFXBUsIRW9z3QFG4zodszog size=50 return_code=
\[2025-10-09 02:09:15.785\] \[info\] set_typing: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net typing=true timeout=10000
\[2025-10-09 02:09:19.549\] \[info\] set_typing: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net typing=false timeout=10000
\[2025-10-09 02:09:19.560\] \[info\] send_message: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net
\[2025-10-09 02:09:19.560\] \[info\] create new group session
\[2025-10-09 02:09:19.560\] \[info\] create new inbound session from earliest known session key: AgAAAAA9YVUrmO0vbY/8cxB6osh2DmV5Cl7er6mFJSZUmEyJMFQ5iVk2hte1nqlDmuFZsRM1fJc7nMPYQmR75knD0sYYex/CnL7SwiwE8Ofh/UCvO39qg3eeaQYKFZLtXqBYy9e/du8/r+19Lvari3k0ao/E+5P+HIuMS+cl0RhiCVGKYFn9tT8wP34lVsnuVzAbAEd0/8HK5y/F8z/t8TpZyQfyOcR+US3oh3DxQDZ/sEAMyi1MxwS5VQ/9iLUCxY4LoVRGpB7SOuzfLNaSDc8yZ7oIYty5bfsne44noqwUdjJWCQ
\[2025-10-09 02:09:20.106\] \[info\] Successfully claimed keys
\[2025-10-09 02:09:21.664\] \[info\] set_read_marker: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net message_id=$Fv5ckzJamCn0m0Uo5lNNnYa2kgZInZwsxVFmyjwiBYo
\[2025-10-09 02:09:55.478\] \[info\] set_typing: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net typing=true timeout=10000
\[2025-10-09 02:44:36.774\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-09 02:44:49.308\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-09 02:53:43.023\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-09 02:53:47.001\] \[info\] TSBindingBrowserTSChat dtor
\[2025-10-09 02:53:47.001\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-16 01:05:34.888\] \[info\] TSBindingBrowserTSChat ctor
\[2025-10-16 01:05:34.888\] \[info\] TSChat library version: 1
\[2025-10-16 01:05:40.099\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-10-16 01:05:40.100\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-16 01:05:40.104\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-10-16 01:05:40.236\] \[info\] Created store from save data, loaded transactionId=1760000959563, searchDbSerial=2
\[2025-10-16 01:05:40.236\] \[info\] Init crypto storage
\[2025-10-16 01:05:40.238\] \[info\] created new group session storage
\[2025-10-16 01:05:40.239\] \[warning\] get key request data: unexpected end of JSON input
\[2025-10-16 01:05:40.304\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-10-16 01:05:40.679\] \[info\] Initial sync… nextBatch=s12480190_1219238854_1001031_1863678_2228878_1_1599278_103534012_0_138212
\[2025-10-16 01:05:40.991\] \[info\] 1 new one time keys are created
\[2025-10-16 01:05:41.552\] \[info\] Initial sync done
\[2025-10-16 01:05:41.552\] \[info\] Connect done
\[2025-10-16 01:05:41.552\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-10-16 01:05:41.572\] \[info\] start: ts_chat_id=1
\[2025-10-16 01:05:41.572\] \[info\] Starting matrix client
\[2025-10-16 01:05:42.103\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-16 01:05:46.801\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-16 01:07:25.825\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-16 01:08:08.103\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“ts-community”,“name”:“🌐 Official TeamSpeak Community Server | Screenshare active 🌐”,“uuid”:“zNOJQHenWkyWm/hHQYMvgN3FL6g=”}\]}
\[2025-10-16 01:08:32.754\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-16 01:08:34.325\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-16 01:21:20.158\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-16 01:21:21.884\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-16 01:23:43.685\] \[info\] TSBindingBrowserTSChat dtor
\[2025-10-16 01:23:43.686\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-23 22:43:59.269\] \[info\] TSBindingBrowserTSChat ctor
\[2025-10-23 22:43:59.270\] \[info\] TSChat library version: 1
\[2025-10-23 22:44:03.379\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-10-23 22:44:03.380\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=CiB6NgE1TnesPMPGPftP6mz0p44KVOuaDle8xj+diK2nIxKUAQpwsjm/yRuT0BPZd4EZbrOdU1EibJvIdOs1kkoLE3/HVq0ywy+04nIAXeZtAGpy6yeuZHLECyZepn7j4sLpDpCh6WIxZAbJDW/DRrkS+t54/KvzmyVEELsSaSss4fK7pREV9n7Xg6tJ7TNTGHgxcrbKCRIg4M6nZ/lSEgiokjD4ic7qKCdoaeXvz099vxBZQE+UyXEYgICAgIDt+bnBASIhAZUA5SJUxPRJiJnFlsDWEA9WnsjI1KlrQH1N6a37C/EBKrABBNQIFa/YmnvvhkdXilbF5pIGTe7u5y47t/JVsfA4AmZ9L0dt0qXBbbhLQIx2FbD2utztfXIL3MmmPJaxXD7TCQEA3lhpecKgocpIjyps49qcdJg3910Y2t8LsX7loEBdJsEAEs6mABjBWoAAAABCVGVhbVNwZWFrIFN5c3RlbXMgR21iSAAA0DPT3gD5YONI4EULFJqxON2cvXFQh5iyGZENCKX0lrgGGAQ1aRgrY8s= => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-23 22:44:03.381\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-10-23 22:44:03.413\] \[info\] Created store from save data, loaded transactionId=1760000959563, searchDbSerial=2
\[2025-10-23 22:44:03.413\] \[info\] Init crypto storage
\[2025-10-23 22:44:03.413\] \[info\] created new group session storage
\[2025-10-23 22:44:03.413\] \[warning\] get key request data: unexpected end of JSON input
\[2025-10-23 22:44:03.487\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-10-23 22:44:03.809\] \[info\] Initial sync… nextBatch=s12676535_1239017110_1033245_1889033_2251684_1_1631957_105274244_0_139500
\[2025-10-23 22:44:04.761\] \[info\] Initial sync done
\[2025-10-23 22:44:04.761\] \[info\] Connect done
\[2025-10-23 22:44:04.761\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-10-23 22:44:04.763\] \[info\] get_member room_id=@afedfvwrblph4mtbkzj2am5ku7qmoxbzd67qb6h6tordnesvs6xae===:chat-3.tmspk.net
\[2025-10-23 22:44:04.764\] \[info\] get_member room_id=@agkqbzjcktcpismithcznqgwcahvnhwizdkks22apvg6tlp3bpyqc===:chat-5.tmspk.net
\[2025-10-23 22:44:04.764\] \[info\] start: ts_chat_id=1
\[2025-10-23 22:44:04.765\] \[info\] Starting matrix client
\[2025-10-23 22:44:05.839\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-23 22:44:12.752\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-23 22:44:52.550\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-23 23:47:15.654\] \[info\] scrollback ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net oldest_message_id=$qdk6PTCRJC72zPcjEyBUIFXBUsIRW9z3QFG4zodszog size=50 return_code=
\[2025-10-23 23:47:19.779\] \[info\] TSBindingBrowserTSChat dtor
\[2025-10-23 23:47:19.779\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-24 19:33:41.372\] \[info\] TSBindingBrowserTSChat ctor
\[2025-10-24 19:33:41.372\] \[info\] TSChat library version: 1
\[2025-10-24 19:33:45.696\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-10-24 19:33:45.697\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-24 19:33:45.698\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-10-24 19:33:45.729\] \[info\] Created store from save data, loaded transactionId=1760000959563, searchDbSerial=2
\[2025-10-24 19:33:45.729\] \[info\] Init crypto storage
\[2025-10-24 19:33:45.730\] \[info\] created new group session storage
\[2025-10-24 19:33:45.730\] \[warning\] get key request data: unexpected end of JSON input
\[2025-10-24 19:33:45.797\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-10-24 19:33:46.137\] \[info\] Initial sync… nextBatch=s12893839_1263108700_1075517_1922210_2280382_1_1669348_107060965_0_140848
\[2025-10-24 19:33:47.069\] \[info\] Initial sync done
\[2025-10-24 19:33:47.070\] \[info\] Connect done
\[2025-10-24 19:33:47.070\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-10-24 19:33:47.071\] \[info\] get_member room_id=@afedfvwrblph4mtbkzj2am5ku7qmoxbzd67qb6h6tordnesvs6xae===:chat-3.tmspk.net
\[2025-10-24 19:33:47.089\] \[info\] get_member room_id=@agkqbzjcktcpismithcznqgwcahvnhwizdkks22apvg6tlp3bpyqc===:chat-5.tmspk.net
\[2025-10-24 19:33:47.090\] \[info\] start: ts_chat_id=1
\[2025-10-24 19:33:47.090\] \[info\] Starting matrix client
\[2025-10-24 19:33:47.621\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-24 19:33:50.817\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-24 19:33:55.319\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-24 19:34:14.988\] \[info\] TSBindingBrowserTSChat dtor
\[2025-10-24 19:34:14.989\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\Y2FiZTNiODRjODhmMDkzNGY3NzFhNmRlYjJkZWNlNWU
\[2025-10-30 22:49:51.239\] \[info\] TSBindingBrowserTSChat ctor
\[2025-10-30 22:49:51.240\] \[info\] TSChat library version: 1
\[2025-10-30 22:49:56.427\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-10-30 22:49:56.429\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2025-10-30 22:49:56.430\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-10-30 22:49:56.430\] \[error\] Failed to load save data (open C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk: The system cannot find the file specified.)
\[2025-10-30 22:49:56.508\] \[info\] Creating fresh store
\[2025-10-30 22:49:56.508\] \[info\] new crypto account on init - fresh
\[2025-10-30 22:49:56.509\] \[info\] created new group session storage
\[2025-10-30 22:49:56.595\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-10-30 22:49:57.662\] \[info\] Login successful
\[2025-10-30 22:49:57.927\] \[info\] Initial sync… nextBatch=
\[2025-10-30 22:49:58.452\] \[info\] 50 new one time keys are created
\[2025-10-30 22:49:58.968\] \[info\] missing group session, request
\[2025-10-30 22:49:59.234\] \[info\] missing group session, request
\[2025-10-30 22:49:59.483\] \[info\] Initial sync done
\[2025-10-30 22:49:59.483\] \[info\] Connect done
\[2025-10-30 22:49:59.483\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-10-30 22:49:59.501\] \[info\] get_member room_id=@afedfvwrblph4mtbkzj2am5ku7qmoxbzd67qb6h6tordnesvs6xae===:chat-3.tmspk.net
\[2025-10-30 22:49:59.502\] \[info\] get_member room_id=@agkqbzjcktcpismithcznqgwcahvnhwizdkks22apvg6tlp3bpyqc===:chat-5.tmspk.net
\[2025-10-30 22:49:59.503\] \[info\] start: ts_chat_id=1
\[2025-10-30 22:49:59.503\] \[info\] Starting matrix client
\[2025-10-30 22:49:59.758\] \[info\] ignore session request from own device
\[2025-10-30 22:50:00.023\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-30 22:50:02.752\] \[info\] tried to override existing group session - dropped key
\[2025-10-30 22:50:03.867\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-30 22:50:08.801\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-30 22:50:09.527\] \[info\] scrollback ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net oldest_message_id=$qdk6PTCRJC72zPcjEyBUIFXBUsIRW9z3QFG4zodszog size=50 return_code=
\[2025-10-30 22:50:09.528\] \[info\] fetch events with token=t2–2652201_1285825205_1116874_1954736_2308964_1_1705596_108707894_0_142161, includeReactions=true
\[2025-10-30 22:50:14.009\] \[info\] set_typing: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net typing=true timeout=10000
\[2025-10-30 22:50:16.844\] \[info\] set_typing: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net typing=false timeout=10000
\[2025-10-30 22:50:16.854\] \[info\] send_message: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net
\[2025-10-30 22:50:16.854\] \[info\] create new group session
\[2025-10-30 22:50:16.854\] \[info\] create new inbound session from earliest known session key: AgAAAACbLAz/lO8P8fYbm+dt0eukkf18Hv9PwVwrt19ubW4+Rw/vfa7rZB7G2a2XdUshekX7pehi6gOhladjWUaGbbyF1i69+0R6s8fLGK4eGb+Q4qglX6lUeuCW1RAxpmxa+rC7EtL9Mis2n1g+3JPV3URE0cTnNLif2z37UeP+BgT9dC4Ejl2Q7Zb3WGhytTDj5d7OuYrxaAG+CsGdjmIGMGt47U2BQBNEv1x0TJuIq9UZNh7pS3YM9x381Bvj3rqQ2iRFmXFvZbkTpNeRROVse/rhfd6avZCVZWWlFeQpFtpbCg
\[2025-10-30 22:50:17.356\] \[info\] Successfully claimed keys
\[2025-10-30 22:50:18.925\] \[info\] set_read_marker: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net message_id=$m3FRQhXvUk8-gcoiN4vRJSo20n6GmTOnvdaPue1aBfU
\[2025-10-30 23:29:40.869\] \[info\] set_read_marker: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net message_id=$7Q5L74XDlw6C7b6W0pz6-pVeUIpnOfFig8VRjnC2Sew
\[2025-10-30 23:29:55.692\] \[info\] set_typing: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net typing=true timeout=10000
\[2025-10-30 23:29:56.317\] \[info\] set_typing: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net typing=false timeout=10000
\[2025-10-30 23:29:56.321\] \[info\] send_message: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net
\[2025-10-30 23:29:56.746\] \[info\] set_read_marker: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net message_id=$6_Y8zHIzQzdf9GuOwltDOzEPdVnImuxmnGg9YdjL00c
\[2025-10-30 23:30:10.129\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-10-30 23:32:55.927\] \[info\] set_read_marker: ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net message_id=$hIdSK9lbVNcVrs9pt9ZPGI1XyHeGG3WYAjZfReJyyP0
\[2025-10-31 00:49:59.484\] \[info\] 2 new one time keys are created
\[2025-10-31 00:49:59.926\] \[info\] Successfully uploaded crypto keys
\[2025-10-31 02:14:01.247\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-10-31 02:15:32.401\] \[info\] TSBindingBrowserTSChat dtor
\[2025-10-31 02:15:32.402\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2025-11-01 20:45:42.341\] \[info\] TSBindingBrowserTSChat ctor
\[2025-11-01 20:45:42.362\] \[info\] TSChat library version: 1
\[2025-11-01 20:45:46.858\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-11-01 20:45:46.859\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2025-11-01 20:45:46.860\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-11-01 20:45:46.889\] \[info\] Created store from save data, loaded transactionId=1761892196322, searchDbSerial=0
\[2025-11-01 20:45:46.889\] \[info\] Init crypto storage
\[2025-11-01 20:45:46.890\] \[info\] created new group session storage
\[2025-11-01 20:45:46.890\] \[warning\] get key request data: unexpected end of JSON input
\[2025-11-01 20:45:46.992\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-11-01 20:45:47.371\] \[info\] Initial sync… nextBatch=s13114073_1285999932_1117202_1955042_2309175_1_1705744_108721586_0_142171
\[2025-11-01 20:45:49.259\] \[info\] Initial sync done
\[2025-11-01 20:45:49.259\] \[info\] Connect done
\[2025-11-01 20:45:49.259\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-11-01 20:45:49.276\] \[info\] get_member room_id=@afedfvwrblph4mtbkzj2am5ku7qmoxbzd67qb6h6tordnesvs6xae===:chat-3.tmspk.net
\[2025-11-01 20:45:49.277\] \[info\] get_member room_id=@agkqbzjcktcpismithcznqgwcahvnhwizdkks22apvg6tlp3bpyqc===:chat-5.tmspk.net
\[2025-11-01 20:45:49.277\] \[info\] start: ts_chat_id=1
\[2025-11-01 20:45:49.277\] \[info\] Starting matrix client
\[2025-11-01 20:45:49.798\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-11-01 20:45:58.460\] \[info\] scrollback ts_chat_id=1 room_id=!wBnmoUEQMKKgcSKcbO:chat-3.tmspk.net oldest_message_id=$sH2AB824VSLhN63T0HZRIT5JM_odvzFc3aX5brpJaKI size=50 return_code=
\[2025-11-01 20:46:09.656\] \[info\] TSBindingBrowserTSChat dtor
\[2025-11-01 20:46:09.656\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2025-11-10 00:11:51.482\] \[info\] TSBindingBrowserTSChat ctor
\[2025-11-10 00:11:51.609\] \[info\] TSChat library version: 1
\[2025-11-10 00:11:55.968\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-11-10 00:11:55.970\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2025-11-10 00:11:55.971\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-11-10 00:11:56.007\] \[info\] Created store from save data, loaded transactionId=1761892196322, searchDbSerial=2
\[2025-11-10 00:11:56.007\] \[info\] Init crypto storage
\[2025-11-10 00:11:56.008\] \[info\] created new group session storage
\[2025-11-10 00:11:56.008\] \[warning\] get key request data: unexpected end of JSON input
\[2025-11-10 00:11:56.060\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-11-10 00:11:56.411\] \[info\] Initial sync… nextBatch=s13168229_1292349878_1125711_1961363_2315380_1_1715436_109161115_0_142512
\[2025-11-10 00:11:57.313\] \[info\] Initial sync done
\[2025-11-10 00:11:57.313\] \[info\] Connect done
\[2025-11-10 00:11:57.313\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-11-10 00:11:57.318\] \[info\] get_member room_id=@afedfvwrblph4mtbkzj2am5ku7qmoxbzd67qb6h6tordnesvs6xae===:chat-3.tmspk.net
\[2025-11-10 00:11:57.336\] \[info\] get_member room_id=@agkqbzjcktcpismithcznqgwcahvnhwizdkks22apvg6tlp3bpyqc===:chat-5.tmspk.net
\[2025-11-10 00:11:57.337\] \[info\] start: ts_chat_id=1
\[2025-11-10 00:11:57.337\] \[info\] Starting matrix client
\[2025-11-10 00:11:57.861\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-11-10 00:11:58.546\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”,“servers”:\[{“address”:“vishcity.ny1.teamspeak. com”,“name”:“Vishcity”,“uuid”:“3EznXmderF+XHg0l2IGv8N0waJY=”}\]}
\[2025-11-10 00:57:21.847\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-11-10 00:57:25.164\] \[info\] TSBindingBrowserTSChat dtor
\[2025-11-10 00:57:25.165\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2025-11-15 09:25:50.641\] \[info\] TSBindingBrowserTSChat ctor
\[2025-11-15 09:25:50.718\] \[info\] TSChat library version: 1
\[2025-11-15 09:25:55.094\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2025-11-15 09:25:55.098\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2025-11-15 09:25:55.102\] \[info\] Matrix client create: matrixHost=chat-5.tmspk. net
\[2025-11-15 09:25:55.169\] \[info\] Created store from save data, loaded transactionId=1761892196322, searchDbSerial=2
\[2025-11-15 09:25:55.170\] \[info\] Init crypto storage
\[2025-11-15 09:25:55.172\] \[info\] created new group session storage
\[2025-11-15 09:25:55.172\] \[warning\] get key request data: unexpected end of JSON input
\[2025-11-15 09:25:55.232\] \[info\] connect: ts_chat_id=1 displayname=Araz985 presence=online
\[2025-11-15 09:25:55.617\] \[info\] Initial sync… nextBatch=s13401823_1319125486_1160096_1986937_2340859_1_1752322_110991909_0_143860
\[2025-11-15 09:25:56.486\] \[info\] Initial sync done
\[2025-11-15 09:25:56.486\] \[info\] Connect done
\[2025-11-15 09:25:56.486\] \[info\] tschat_connect err=0 home_server=chat-5.tmspk. net
\[2025-11-15 09:25:56.494\] \[info\] get_member room_id=@afedfvwrblph4mtbkzj2am5ku7qmoxbzd67qb6h6tordnesvs6xae===:chat-3.tmspk.net
\[2025-11-15 09:25:56.495\] \[info\] get_member room_id=@agkqbzjcktcpismithcznqgwcahvnhwizdkks22apvg6tlp3bpyqc===:chat-5.tmspk.net
\[2025-11-15 09:25:56.495\] \[info\] start: ts_chat_id=1
\[2025-11-15 09:25:56.495\] \[info\] Starting matrix client
\[2025-11-15 09:25:57.015\] \[info\] set_presence ts_chat_id=1 presence=online status_message={“presence”:0,“status_msg”:“”}
\[2025-11-15 09:26:01.963\] \[info\] TSBindingBrowserTSChat dtor
\[2025-11-15 09:26:01.963\] \[info\] Save data path: server_identifier=chat-5.tmspk. net specifier=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 => C:\\Users\\Erazmus Bish\\AppData\\Local\\TeamSpeak\\Cache\\Default\\tschat\\NmZjZGMwNzRhYmU1NzRhZTg5ODEzODg3MzhhOTk2NTk
\[2026-02-10 00:53:35.149\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 00:53:35.294\] \[info\] TSChat library version: 1
\[2026-02-10 00:53:40.397\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2026-02-10 00:53:40.397\] \[info\] Empty credentials on create detected, requesting new credentials.
\[2026-02-10 00:53:40.398\] \[error\] Failed to reset tschat credentials, aborting
\[2026-02-10 00:53:50.430\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2026-02-10 00:53:50.431\] \[info\] Empty credentials on create detected, requesting new credentials.
\[2026-02-10 00:53:50.431\] \[error\] Failed to reset tschat credentials, aborting
\[2026-02-10 00:54:10.454\] \[info\] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=**CENTRAL**
\[2026-02-10 00:54:10.454\] \[info\] Empty credentials on create detected, requesting new credentials.
\[2026-02-10 00:54:10.454\] \[error\] Failed to reset tschat credentials, aborting
\[2026-02-10 00:54:17.900\] \[info\] TSBindingBrowserTSChat dtor
\[2026-02-10 00:54:50.738\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 00:55:50.694\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 00:55:55.052\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 00:56:44.058\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 00:57:29.592\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 00:58:08.325\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 01:01:55.729\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 01:02:09.778\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-10 01:05:03.348\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 01:55:36.473\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 01:56:27.164\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 01:59:46.806\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 02:00:28.269\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 02:00:54.197\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 02:03:32.200\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 02:06:15.072\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-11 02:10:15.137\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-12 01:06:43.366\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-12 01:21:26.883\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-12 01:22:29.494\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-12 01:23:20.677\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-12 01:23:25.361\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-13 14:02:06.333\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-14 14:56:46.153\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-14 14:57:07.725\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-14 14:57:28.950\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-19 00:59:44.463\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-19 01:12:18.615\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-19 01:13:18.253\] \[info\] TSBindingBrowserTSChat ctor
\[2026-02-23 23:15:31.257\] \[info\] TSBindingBrowserTSChat ctor
If the DMP file is created after trying to start, please upload it to drive or another file sharing service.
Right sorry here are the Tslog and the DMP
Thank you, I’ve forwarded them to the devs to check.
