Connection to server
good day. Does everyone have a problem that doesn’t connect to TS5 servers immediately after switching on? And it connects normally after rebooting the program.
Edit: This happens every time TS5 is turned on, which helps restart. And so every time I launch the vehicle. OS Win10 and Rosa Linux
it’s not too much info.
the ts5 client isn’t work or the server?
if the client does it all the time or only for the first time/day?
what operating system you are using?
other information?
try run as administrator just a tipp
Does not help. But Linux is also a problem.
this error is on windows or on linux?
Yes, this happens both in windows and in Linux.
the problem also persists attached screenshot
AFAIK this is a known issue. From my experience it happens if someone tries to connect to server immediately instead of waiting a bit to allow TS to load completely.
Maybe try waiting until everything loads, that is a minute or so.
I tried and after 5 minutes to connect the same garbage, only restarting helps
Same here. Also have large packet loss and it loses connection often.
The connection/race condition/whatever on startup thing is a known issue we’re looking in to.
That’s a separate server problem rather than this client one! :slight_smile:
Sure, just mentioned it, so maybe someone else has the same problem and I won’t be the only lucky one :sweat_smile:
And when will you solve this connection problem? It’s somehow not very comfortable to restart the client constantly when you turn on the PC
There is either a server or a problem with the Internet
