It is a stupid question but i can’t edit permissions in my client?
I searched on internet and saw pictures of a complete different permissions screen. Can anyone help me?
This is how i see it btw:
I am trying to set icons up for a server me and my buddy’s are making and I am getting the same error every time I try to upload an icon for the server groups. the file is smaller then 8 kb so thats not the issue.
Hello the message is clear the transfer port is not working if you have created a file (ts3server.ini) to modify the default ports, please check that the transfer port for example on YaTQA ► Statistics ► File transfer port is the port you selected.
Hello everyone, I have a root server on which Pterodactyl is installed. I created a TeamSpeak Server with the program and always get the following error message when uploading icons:
“<18:48:06> Transfer “icon_26071999” reported: (could not open file transfer connection)”
I deactivated the Ubuntu firewall and already released the ports. Nothing worked, does anyone have a solution or an idea?
startserver via “createinifile=1” start option (./ts3server_startscript.sh start createinifile=1, then you will have ts3server.ini file, adjust the “filetransfer_port=” setting, and put port eg 30033, then check your firewall, restart server. It will work.
anyone know how to fix “Transfer “avatar” reports: (could not open file transfer connection)” its poping out after try to change avatar, and i cant load users avatars D: (i try open a ports, firewall config, and thats dont help me)
