Graphics Blackout while Screensharing Godot project while other Teamspeak 6 beta5 user is watching stream
I was testing the screensharing of a godot project launch with my bro, but then both my monitors suddenly went blank. A monitor blackout has never happened on it’s own without TeamSpeak screensharing at the same time, so decided to open an issue.
My brother was using an Apple Silicon Mac using a slightly older TS6 beta client, hes in a different timezone, so cant get that at the moment.
My system:
  • Linux Mint 22.3, Cinnamon/X11
  • AMD Radeon RX Vega GPU, amdgpu driver
  • Kernel 7.0.0-38-generic; Mesa 25.2.8
  • Godot 4.7.2
  • TeamSpeak 6.0.0-beta5, build 1791901251
While sharing the entire screen with a viewer actively watching, launching the Godot project causes the local displays to go completely black and requires a computer restart. In the first confirmed test the remote viewer saw a frozen Godot initialization screen. Joining alone did not cause that crash.
I reproduced this with an Ubuntu viewer on the same TeamSpeak client build as well. I recorded the blackout with my phone, can share that recording if requested, as well as more detailed logs captured with the help of codex+gpt.
Tried Godot 4.7.2 with Nokorpo/LibreAim: Free and open source FPS aim trainer made with Godot. - Codeberg.org on nvidia gpu, hyprland 7.2.9-arch1-1, that worked without issues. You can send me the recording + logs (~/.cache/TeamSpeak/Default/logs - the ts5client_*.log of an instance in which you started the screenshare). Most likely, we will also need to debug what pipewire is doing during the capture and maybe system events to check if a driver crashes/overloads during capture. PM me and we can chat further :)
Thanks for looking into this, pm’d on TeamSpeak
Messaged with revide, and we confirmed it’s an AMD driver issue.
Turning off hardware acceleration in Settings > Video worked to prevent this blackout/crash scenario for my setup.
