so i use push to talk but when i join a server AND ONLY WHEN I JOIN A SERVER, i hear my own mic, ITS ONLY TS the only way i can stop the constant buzz and such is to disable it in windows but then i cant talk…i updated, reinstalled, restarted pc…nothing is working…NOTHING
are you sure that the correct output is set? you may have a seperate output for mic monitoring, depending on your headset/ software. make sure that this isn’t selected
