So basically I use multiple tabs on the same server, however recently ive ran into a issue where i can only keep once mic active and the rest show up as blocked rather than muted. Any suggestions?
If you have the same capture profile selected in all tabs, you can only talk in one tab. To talk across multiple tabs at once, you need different capture profiles.
Or set a hotkey to switch between the individual server tabs if you are in a game and you can’t swap to TS
