I’m trying to create a hotkey for my Virpil throttle for PTT, however when I try and
select a hotkey it picks the button i press, but waits until a second key is pressed, and records
it as a combo.
Is there a config file i can go edit and remove the second key, or some way of making it know this hotkey is only a single key?
I have another key set for my mouse, and it knew it was a single key…
Thanks in advance.
TS 3.5.1
Gamepad and Joystick Hotkey Support V 1.2
