Greetings!
I don’t know if you know, but how often can I apply for the “Sponsorship” license? I have already been rejected once and it says that the data is “kept” for 6 months. What do I have to understand by this?
Stay healthy!
Best regards, Justin
Your data is saved for 6 months to avoid abuse in any ways. After 6 months, then every data from you gets deleted which you applied with.
I’m not sure how much you can re-apply, or if there’s even a way to do this. If you have good reason then it may can effect something.
