How to import a Identity from TS3
It’s currently not possible to do anything until you sync some identity. Would be nice if we could import identities without syncing them. (Or if you’d tell us which files to edit for this.)
Does this not work?
That looks slightly different on my end…
Looks more like your client is broke :smiley:
Don’t mind the colour differences, but the rest is definitely not as it should be. I’d suggest reinstalling TS to see if that fixes the problem.
Your theme looks really neat. I just downloaded the client for linux from the website…
Ok, so just restarting the whole app helped. I thought its blank due to missing identities, as an MVP…
