How can I interact programmatically with TS3 Client?
I need ability to start recording conversation and stoping.
I find couple ways:
ClientQuery plugin - don’t see tool to start recording
Control plugin - only biz devs can request for access to Control DLL
PluginSDK - I will try. Do you think is a only way to do that?
Hello there,
You mean something like:
Tools > Start recording
or
Ctrl+Shift+R
It works fine and makes other people aware of the recording via vocal announcement
Exactly. I know that TeamSpeak has build that function but I need to run it from my program.
I should write it clear.
I want write program to start recording. I need that to be able save specific timestamp when I started and ended.
