Hey i am having issues with my TS server i can join with my ipv4 but that is a private network so my domain company cant put a private IP in my Domain Ragemalik.com i cant use my public ip to join my TeamSpeak What can i do? this is the ip 192.168.0.52 would you mind testing it from a different IP? Please tell me if it works and how i can impliment my public ip for my TeamSpeak server
IS that all i need to do? I am also on windows 10 64bit
Hey,
Sorry i did not know that i also dont have another server but i dont know which is it i dont want to delete the right one i have just tried to use my public ip and it did not work
and sorry i need to do another post because i keep on pressing reply to the thread instead to you and i think it will not give you a notification if i did not reply to you.
Sorry about that
Do I do this in the inbound and outbound rules in the firewall? Or do I need to access my WIFI settings? I have added the rules for the outbound and inbound if that’s what you are talking about
I am currently doing that 1min
Thank you sooo much! it worked!!!
I have one more question if you would mind answering
I have roles (server groups) so i have a YT group the join power is higher than the Clan group so people with the YT role can join the Clan VC because YT has a higher Join power
is there a way the YT rank cant join Clan even though the join power on the channel is set to a lower leven then the YT ranks join power? @FakE
