Hi there.
My problem would be that it shows on the MyTeamSpeak page that there are 14 Badges but unfortunately I can’t activate them in TeamSpeak even though I’m logged in to my profile.
Try to clear your cache in the settings.
Tools -> Settings -> Security
Thanks a lot for the help but unfortunately the problem is not solved.
Thanks for the reply, I asked the support to help but unfortunately they told me to post my problem on the forum. Maybe a TS reinstallation can help?
Reinstalling can be a solution, but it doesn’t have to be.
First, please make sure that your cache folder is not empty or destroyed.
C:\User\USERNAME\AppData\Roaming\TS3Client\Cache\ Badges
Also make sure that synchronisation is enabled, which you can find in the options under MyTeamSpeak.
