Sent: 16384/301976 bytes
Sent: 212992/301976 bytes
Sent: 301976/301976 bytes
Error: 201
AccessDenied
Invalid according to Policy: Policy expired.F2C09DBCDE08827BsVst3Is8ZnoksfboZC/3mS8P9XOFCxlHqOdJOVEp313EmN5jQu378aqQx2hO3mNvoCghj2dKQPs=
Error: 201
AccessDenied
This report does not really say anything.
Please read the top of this post and scroll a bit down to
Your client has crashed (or does not start on Windows)?
Moin und zwar ich brauche hilfe weil ich sonst keine Ahnung davon habe weis du das oder?
mfg xXxGamerPascal2210xXx
Note that the forum is English only.
What @Rikku’s redirect (TeamSpeak - Official TeamSpeak Community Forum) means:
Your post is missing important information.
Please show your crashdumps.
You can find them in the following directory: %AppData%/TS3client/crashdumps
What client version and operating system are you using?
Guten tag wie soll ich das denn Hochladen soll ich ihr ein Link reinmachen von google drive oder
You can upload it for example via Google Drive or Dropbox.
Du sollst auf English antworten!!! -> You Should Answer the Questions they ask in English.
Thanks for Understanding.
Im not sure if this helps you,
But maybe you could try to reinstalling the Teamspeak 3 Client and try out if it works then, too you could just copy the crash dumps into the chat…
greetings Olf
Hello, I have to reinstall it all over the place but you are there are the Chras dumps https://drive.google.com/drive/folders/1NjjGCsmmdbSvfHJp7x_NvriqGkX5Gz78?usp=sharing
