Multiple instances of connection status
make it available to open up multiple Connection status instances(one per user), like you could in ts 3
That’s already possible.
grafik
can you explain how?
when I try to open another instance the first one that was opened closes automatically
Ah you mean the connection info and not status.
No that window can only be opened once. There can only be on window of that type.
Are there any plans on adding an ability to open multiple instances of it?
And is there a reason it is named differently
the only difference is that in connection info you can see the ip address?
