Myteamspeak ID is invalid error
<00:04:56> The TeamSpeak server could not validate your myTeamSpeak ID. Some myTeamSpeak related services are not available.
<00:04:56> Reconnecting might solve the issue.
<00:04:56> myTeamSpeak ID is invalid
i have this error after join my friend server on teamspeak3 3.6.2 version. but other servers are not giving me this error. also i was using teamspeak5 and with that version of teamspeak i was not getting these errors on my friend server. but now i’m getting why?
Hello @st3rbenvl
Please take a look at the quote:
It must be ensured that the latest server version is used. As well as that, all necessary ports are enabled. If it is not because of them, your friend needs to update his TeamSpeak server or check if any ports that are important are enabled, see quote
version of this server. is it outdated?
Yes it is outdated you can see the release date. Its from 2019
Thanks. So when i was using teamspeak5 beta77 i was not getting this error cause beta77 version was okay to this version of teamspeak server?
Im TS5 most of the errors get logged in the background and not shown in any chat, so it probably has had problems verifying your myTS ID but didn’t inform you about that.
ahh it make sense now. thank you so much!!
