No error when the max file size limit is too low for uploading icons
I just ran into this same issue. It seems like the upload silently fails if the icon is not the correct dimensions. There is no dialog or prompt to explain why the upload has failed, it actually appears to be successful. No errors in the server logs for this either.
Please check this permission for the Server Admin Group:
Thank you! This absolutely worked, but in the future there should be some kind of error message to explain this.
Yep, I’ll note that down and forward it.
TID: 2015
This issue should be fixed with the next update. 6.0.0-beta4
