that’s really hard. expensive servers with no normal ip with few settings. i know it costs a lot and you can’t do much now. but as soon as the own server files will be there, i will definitely host it myself
i can help you with the SRV and CNAME
Just figured this one out recently. It appears, at least from what I’ve seen, the communities’ teamspeak.com domains seem to point to a series of different IP addresses and don’t use port 9987.
You can however still route to your community via your own domain using an SRV record.
Determine which port your community is running on
They may all be the same, however I’m not sure. Try launching the teamspeak3 client through a terminal and connect to your community. Keep an eye out for what port your client decides to connect to the server with.
Set up your SRV record
You can set up your SRV record according to the FAQ linked below, make sure you use the port you determine the community is using.
I haven’t tried using a TSDNS SRV record, but the regular record seems to work for me.
For example, the below record would allow you to connect to community.ny1.teamspeak.com running on port 1337 via ts.yourdomain.com
_ts3._udp.ts. 1 IN SRV 0 5 1337 community.ny1.teamspeak.com
Depending on your domain registrar this may take some tinkering, I personally use squarespace and it was a headache to get working.
it has actually been obvious that it is not the default port because otherwise each community server must have its own IP and Ts6server instance.
Hi tomorrow (today) after work I can help you if you want
1 add a Cname 2 make a SRV to the Cname with the teamspeak port
Hey
i booked a community ts6 server from you.
But one big thing is our dns name that our old friends can find us.
and your current setup of your servers dont allow any sort of redirection.
Can you please implement this that we can use our domain to connect to your hosted servers?
Thanks!! ![]()
Use a cname and a srv record
I tryd that before, but this dont works for me. You did it and got a working dns redirevtion with cname and srv?
If yes please help me ![]()
Do you know your teamspeak port?
Hey, no its just a hosted sub.domain.
How should i know? It seems its behind a cdn because there are a lot of its relolved
- give me your ts6 server ip i will find your server port
- What DNS provider are you using?
Oh that would be great!!
gammelbaeren.fra2.teamspeak.com
I use internex.at
There i can make nearly every entry by myself.
Thanks man
i made this. should be correct. nslookup showed me that port. but dont work.
Maybe dns infos is taking some time to get around ![]()
use ts3 srv
_ts3.udp
you mean hostname just “_ts6.udp” and not “_ts6._udp.ts6” ?
_ts3._udp.ts6
cuz teamspeak6 server is just base ts3 with bit more extras…
yes
