Lost Admin on my server
hello team, I created a teamspeak server, then accidentally deleted the admin role. now i have no more permissions !!! please help me … (port not yet released)
Assuming you have the query password for the user “serveradmin” when you made the server, you are able with that to recreate the “Server Admin” group and reassign it to yourself and create a privilege key and then use it. If you don’t you are basically screwed.
The other possible case is to touch the database file directly, but this is not supported and not recommended if you are not good at.
I have done this a few times myself int he beginning and found it easiest to just remake the server. I.e. delete the whole server folder and start from scratch.
