BetterChat
BetterChat is an unofficial addon for TeamSpeak 5 and aims to provide a better chat experience for the TeamSpeak 5 client. It enables support for BBCodes, improving messages sent by TeamSpeak 3 users, and automatic rich embeds for any website, including dedicated embeds for video, audio, image and twitter content. It works in both compact and detailed view.
BBCode support
BetterChat readds support for BBCodes in chat, just like in TeamSpeak 3. Currently the following tags are supported:
Name | Syntax | Example |
bold | [b]text[/b] | |
code | [code]text[/code] | |
color | [color=hexcode]text[/color] or [color=color]text[/color] | |
italic | [i]text[/i] | |
spoiler | [spoiler]text[/spoiler] | |
strike | [s]text[/s] | |
underline | [u]text[/u] | |
url | [url]link[/url] or [url=link]text[/url] |
Rich Embeds
BetterChat supports automatic rich embeds for any website, including dedicated embeds for video, audio, image and twitter content. Due to technical limitations, not all video and audio formats are supported at the moment.
Video Embed
Audio Embed
Twitter Embed
Generic Embed
Styling
Custom styling for the image preview can be changed in the style.css
Rich embeds use the already existing css classes of the TeamSpeak client and should be compatible with already existing themes.
Installation
Notes:
- Manual installation only works for TeamSpeak 5 beta 70
- Depending on your installation directory you may need elevated permission privileges
- The installation process needs to be repeated after each TeamSpeak update
- Please check the compatibility section before installing BetterChat
Installer
Installation steps:
- Download the installer for your operating system from here
- Start the installer
- Select your TeamSpeak installation directory
- Select âBetterChatâ
- Click on âInstallâ
Manual
Installation steps:
- Navigate to your TeamSpeak installation directory
- Navigate to
./html/client_ui/
- Open
index.html
in that directory with an editor and copy all contents from theindex.html
of this repository before</head>
and save the file - Create a new folder named
betterchat
- Copy all contents from
src/
into the newly created folder - And you are done! You can now start TeamSpeak
Configuration
BetterChat can be enabled and disabled while TeamSpeak is running.
Just go to the settings menu inside TeamSpeak and navigate to Chats.
There you can toggle specific features, like BBCode support or Rich Embeds, or enable and disable the addon entirely.
Compatibility
TeamSpeak | Windows | Linux | MacOS |
Beta 77 | 2.5.0+ | 2.5.0+ | 2.5.0+ |
Beta 76 | 2.4.0+ | 2.4.0+ | 2.4.0+ |
Beta 75 | 2.3.0+ | 2.3.0+ | 2.3.0+ |
Beta 74 | 2.1.0 - 2.2.1 | 2.1.0 - 2.2.1 | 2.1.0 - 2.2.1 |
Beta 73 | 1.2.0 - 2.2.1 | 1.2.0 - 2.2.1 | 1.2.0 - 2.2.1 |
Beta 72 | 1.1.0 - 2.2.1 | 1.1.0 - 2.2.1 | n/a |
Beta 71 | n/a | ||
Beta 70 | 1.0.0 - 1.0.4 | 1.0.0 - 1.0.4 | 1.0.0 - 1.0.4 |
Acknowledgements
This addon is inspired by the TeamSpeak UNOFFICIAL Plugin Installer by Gamer9200
