I am currently searching a C++ library to connect to a teamspeak 3 server via webquery. Has anyone ever used something like that? Does anyone know where I could find this?
Greetings
Greetings
The webquery (i think you mean http/s?) is quite new, I don´t think there’s a c++ library available yet. I am currently writing an implementation in go for it if that helps.
Do you have a github site for your drafts? I’d like to try it, thanks.
It is in a really early state. It is on github, but currently it’s a private repo. I think i will put it in public by the end of the week.
Any updates/previews?
Thanks for your interest. I think I will need a few more days. I want to have a usable library before making it public.
Finally I got to a point where are enough features to make the repository public.
Please note, that it is WIP and definitely just an api-wrapper and no bot-framework.
I implemented a simple event system (using raw), but that is REALLY wip!
You can find the repo link here.
