Screenshare viewing - audio crackling
Viewing a screenshare looks and sounds fine for a while, then the audio will begin to crackle
The crackling can be eliminated by setting clock.force-quantum 128
Strangely this also only is a temporary fix, and the same crackling occurs after some time
No matter how much this value is increased, the crackling always seems to return
Kernel: Linux 6.18.3-2-cachyos
CPU: AMD Ryzen 7 5800X (16) @ 4.85 GHz
GPU: AMD Radeon RX 6750 XT [Discrete]
(audio info)
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 224073
Tile Size: 65472
Server Name: PulseAudio (on PipeWire 1.4.9)
power management set to performance
Thanks for the detailed report, I’ll forward this to QA to investigate.
Also a quick solution I’ve noted is simply rejoining the stream when the crackling starts
Same here. I think it has existed since the first build (build 3 at least had it, and the update didn’t help). Hotfix or temporary fix would be nice, rejoin screenshare work but can cause information lose between reconnection
Same for a friend of mine.
Fresh install of teamspeak 6 after a while maybe like 30 min, audio starts crackling and can only be fixed while rejoining the stream or restarting it.
Windows 11 latest client.
i9 13900k, rtx 4090, gigabyte z790 mainboard.
Yes, i have had this issue for really long time and i hoped for beta4 to include a fix for that, since it was said before several times that the update includes several screensharing fixes
I was able to reproduce the issue now. Let’s hope that our dev can reproduce it too :P
TID: 2287
In case they won’t be able to, u can always invite dev to your house and test it just in front of his eyes :rofl:
The issue should be solved with 6.0.0-beta5, please retest and provide feedback.
