Setting up TS6 Server on Synology using Container Manager
I’m using the following image:
teamspeaksystems/TeamSpeak 6-server:latest
and I’m configuring the container manually (without a Compose YAML file)
The server generally runs, but not when I try to mount a directory…
In my case: /volume1/docker/TeamSpeak 6:/var/tsserver
When I mount this directory, the log shows the following:
2026-10-01 13:49:51.833759 | ERROR | ServerLibPriv | | Failed to create log directory “/var/tsserver/logs”
I’ve been tinkering with permissions for ages but can’t seem to find a solution…
The TS3 server container has been running for years without any issues and was configured the same way I configure all my containers—without causing any problems.
Does anyone have any ideas about what I could be doing differently?
Thanks in advance
Check if the server has sufficient read and write permissions. Connect to the NAS over SSH and assign ownership directly to 9987:9987:
# Set folder ownership to TeamSpeak's container UID/GID
chown -R 9987:9987 /volume1/docker/teamspeak6/teamspeak-data
# Apply standard secure permissions
sudo chmod -R 755 /volume1/docker/teamspeak6/teamspeak-data
(Avoid using chmod -R 777 as it opens unnecessary write permissions to all local processes and accounts).
It works ! :D This Problem drove me insane -.-
Thanks alot !
