[Solved] Problems with my badge
Hello!
I have a little problem. I recently got the “Testing” Badge, because I received the all-new TeamSpeak Beta. But on my original identity, only I can see my badge. Other clients cannot see it. I’ve tested with a new identity, there it works fine.
Additional info: My original identity is in a server query group of my server with nearly every right, is it possible that the problem comes from this?
I’m german, sorry for any mistakes.
~ mariusHSK05
In the server you trying to connect, either from the “Connections -> Connect” or from your “Bookmarks” you need the check the button that says “Enable myTeamSpeak features”.
Hey Alligatoras!
Thank you very much! That helped me!
