Hello, my dears,
I have a tiny problem that I might need your help with. A long time ago I made an SRV record in my DNS settings:
SRV _ts3._udp.mydomain.de 0 5 9987 ts 86400
For this I found the following entry in the client protocol:
08/04/2021 14:44:09 ClientUI Info Connect to server: ts.mydomain.de
08/04/2021 2:44:09 PM ClientUI Info Trying to resolve ts.mydomain.de
04.08.2021 14:44:09 TSDNS Info A / AAAA DNS resolve successful, "ts.mydomain.de" = (h: 2a01: 4f8: xxxx: xxxx :: 1 p: 0), (h: xxx.xxx. xxx.xx p: 0)
04.08.2021 14:44:09 TSDNS Info A / AAAA DNS resolve for possible TSDNS successful, "ts.mydomain.de" = (h: 2a01: 4f8: xxxx: xxxx :: 1 p: 0), (h: xxx .xxx.xxx.xx p: 0)
04.08.2021 14:44:09 TSDNS Info A / AAAA DNS resolve for possible TSDNS successful, "mydomain.de" = (h: 2a01: 4f8: xxxx: xxxx :: 1 p: 0), (h: xxx.xxx .xxx.xx p: 0)
04.08.2021 14:44:09 TSDNS Info SRV DNS resolve unsuccessful, "_tsdns._tcp.mydomain.de" DNS server returned answer with no data
04.08.2021 14:44:09 TSDNS Info SRV DNS resolve unsuccessful, "_ts3._udp.ts.mydomain.de" Domain name not found
04.08.2021 14:44:11 TSDNS Info TSDNS queried unsuccessfully 2a01: 4f8: xxxx: xxxx :: 1: 41144
04.08.2021 14:44:13 TSDNS Info TSDNS queried unsuccessfully xxx.xxx.xxx.xx: 41144
08/04/2021 14:44:13 TSDNS Info No TSDNS found
This morning I changed the SRV entry to:
SRV _ts3._udp.mydomain.de 0 5 9987 ts.mydomain.de. 86400
Unfortunately nothing has changed in the client protocol, the same errors are still there. Can you tell me or write where my mistake is? Oh, server is operated by Hetzner when it is important.
Forget: The A and AAAA records are set correctly and refer to the IP of the server.
Thanks
