Hello, my friend has an issue that when he tries to open up his teamspeak then this pops up and after 3 seconds crashes. After it crashes it reopens itself 2-3 times and then crashes and nothing happens.
What should we try to do?
He sould add the -safemode parameter to his shortcut. This will disable plugins and the client may be usable again.
Now he should remove all 3rd party plugins. If he then wants to use the plugins again, he should make sure that the plugin version and the client version is compatible.
When he has found a compatible version and it still does not work, he should reach out to the developer of the plugin, here we cannot help you with software programmed by other developers.
