Streaming Window Doesn’t Close After Starting Broadcast
When I start a broadcast in TeamSpeak 6, the streaming window stays open (instead of minimizing/closing), but the stream itself works fine. However, if I click outside the streaming window, the broadcast stops unexpectedly.
I’ve noticed that for some users, the window disappears automatically after starting the stream—but not for me. Is this a bug, or is there a setting to control this behavior?
Details:
  • TeamSpeak 6 version: 6.0.0-beta2
  • OS: Windows 11
  • Steps to reproduce: Start broadcast → window persists → click outside → stream stops.
This is an already known issue and will be fixed with an upcoming release. It has to do with a failed connection attempt that is still in the activity sidebar.
check my video , i know after see the video you understood https://youtu.be/Sogh1-KOiKs
Thanks for reporting. That was sometimes caused by failed connection attempts to servers. This issue is already fixed in our internal alpha versions.
