Im have a problem on the ts3 server I use, I get disconnected all the time sometimes 30-60 times per hour, this server is updated to last version… and the same happens for teamspeak.voice, I keep disconnecting for no reason, my Internet connection is pretty good. So I got invited to a ts3 server that uses old version, 3.1.10, and only here I already have 12 hours online without any problem, so my problem is only for new versions, any idea what could I do to fix it?
07/04/2020 03:39:11 ClientUI Info Connection lost, want autoreconnect = 1
07/04/2020 03:39:12 ClientUI Info Autoreconnecting
07/04/2020 03:39:12 ClientUI Info Connect to server: lancheros.tibia.run
07/04/2020 03:39:12 ClientUI Info Trying to resolve lancheros.tibia.run
07/04/2020 03:39:12 TSDNS Info A/AAAA DNS resolve unsuccessful, “lancheros.tibia.run” DNS server returned answer with no data
07/04/2020 03:39:12 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “tibia.run” =(h: 198.27.104.48 p:0)
07/04/2020 03:39:12 TSDNS Info SRV DNS resolve unsuccessful, “_tsdns._tcp.tibia.run” DNS server returned answer with no data
07/04/2020 03:39:13 TSDNS Info SRV DNS resolve successful, “_ts3._udp.lancheros.tibia.run” =(h: ts.tibia.run p:10504)
07/04/2020 03:39:13 TSDNS Info A/AAAA DNS resolve successful, “ts.tibia.run” =(h: 51.161.71.101 p:0)
07/04/2020 03:39:13 ClientUI Info Lookup finished: ip=51.161.71.101 port=10504 query=lancheros.tibia.run error=0
07/04/2020 03:39:13 ClientUI Info Resolve successful: 51.161.71.101:10504
07/04/2020 03:39:13 ClientUI Info Initiating connection: 51.161.71.101:10504
07/04/2020 03:39:13 ClientUI Info Connect status: Connecting
07/04/2020 03:39:13 PktHandler Devel Puzzle solve time: 0
07/04/2020 03:39:14 ClientUI Info Connect status: Connected
07/04/2020 03:39:14 ClientUI Info Connect status: Establishing connection
07/04/2020 03:39:14 ClientUI Info Connect status: Connection established
07/04/2020 03:39:14 TSDNS Info TSDNS queried unsuccessfully 198.27.104.48:41144
07/04/2020 03:39:14 TSDNS Info No TSDNS found
07/04/2020 03:39:20 Windows Audio Session Debug WAS::associateAECDevice-enter - {0.0.1.00000000}.{2bea936e-ae9c-4817-b073-a51f3ebeac2d}
07/04/2020 03:39:20 Windows Audio Session Devel DeviceDeleteList::queue_device_delete - enter: Altavoces (Realtek® Audio) - DeviceDeleteList
07/04/2020 03:39:20 Windows Audio Session Devel DeviceDeleteList::queue_device_delete - leave: Altavoces (Realtek® Audio) - DeviceDeleteList
07/04/2020 03:39:20 Windows Audio Session Devel DeviceDeleteList::clear_queue - enter - DeviceDeleteList
07/04/2020 03:39:20 Windows Audio Session Devel DeviceDeleteList::clear_queue - leave - DeviceDeleteList
07/04/2020 03:39:20 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Altavoces (Realtek® Audio)
07/04/2020 03:39:20 Windows Audio Session Devel Initializing with mix format. - Altavoces (Realtek® Audio)
07/04/2020 03:39:20 Windows Audio Session Info Initialized with 2 channels in 32bit, 48kHz. - Altavoces (Realtek® Audio)
07/04/2020 03:39:20 Windows Audio Session Devel WAS Buffer size: 1056 - Altavoces (Realtek® Audio)
07/04/2020 03:39:20 Windows Audio Session Debug WAS::associateAECDevice-leave - {0.0.1.00000000}.{2bea936e-ae9c-4817-b073-a51f3ebeac2d}
07/04/2020 03:39:20 Windows Audio Session Devel [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Altavoces (Realtek® Audio)
07/04/2020 03:41:29 PktHandler Info Dropping client 131 because of ping timeout 19 0 0
07/04/2020 03:41:29 SCHandler Warning Got command data while disconnected, dropping
07/04/2020 03:41:29 ClientUI Info Connect status: Disconnected
07/04/2020 03:41:29 ClientUI Info Connection lost, want autoreconnect = 1
07/04/2020 03:41:30 ClientUI Info Autoreconnecting
07/04/2020 03:41:30 ClientUI Info Connect to server: lancheros.tibia.run
07/04/2020 03:41:30 ClientUI Info Trying to resolve lancheros.tibia.run
07/04/2020 03:41:30 TSDNS Info A/AAAA DNS resolve unsuccessful, “lancheros.tibia.run” DNS server returned answer with no data
07/04/2020 03:41:30 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “tibia.run” =(h: 198.27.104.48 p:0)
07/04/2020 03:41:30 TSDNS Info SRV DNS resolve unsuccessful, “_tsdns._tcp.tibia.run” DNS server returned answer with no data
07/04/2020 03:41:30 TSDNS Info SRV DNS resolve successful, “_ts3._udp.lancheros.tibia.run” =(h: ts.tibia.run p:10504)
07/04/2020 03:41:30 TSDNS Info A/AAAA DNS resolve successful, “ts.tibia.run” =(h: 51.161.71.101 p:0)
07/04/2020 03:41:30 ClientUI Info Lookup finished: ip=51.161.71.101 port=10504 query=lancheros.tibia.run error=0
07/04/2020 03:41:30 ClientUI Info Resolve successful: 51.161.71.101:10504
07/04/2020 03:41:30 ClientUI Info Initiating connection: 51.161.71.101:10504
07/04/2020 03:41:31 ClientUI Info Connect status: Connecting
07/04/2020 03:41:31 PktHandler Devel Puzzle solve time: 0
07/04/2020 03:41:31 ClientUI Info Connect status: Connected
07/04/2020 03:41:31 ClientUI Info Connect status: Establishing connection
07/04/2020 03:41:31 ClientUI Info Connect status: Connection established
07/04/2020 03:41:32 TSDNS Info TSDNS queried unsuccessfully 198.27.104.48:41144
07/04/2020 03:41:32 TSDNS Info No TSDNS found
07/04/2020 03:46:44 Info Memory usage: 87.38 MiB
07/04/2020 03:51:16 PktHandler Info Cleaning up connection because of 12 resends of COMMAND packet
07/04/2020 03:51:16 PktHandler Info Dropping client 98 because of resend timeout
07/04/2020 03:51:16 ClientUI Info Connect status: Disconnected
07/04/2020 03:51:16 ClientUI Info Connection lost, want autoreconnect = 1
07/04/2020 03:51:17 ClientUI Info Autoreconnecting
07/04/2020 03:51:17 ClientUI Info Connect to server: lancheros.tibia.run
07/04/2020 03:51:17 ClientUI Info Trying to resolve lancheros.tibia.run
07/04/2020 03:51:17 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “tibia.run” =(h: 198.27.104.48 p:0)
07/04/2020 03:51:17 TSDNS Info SRV DNS resolve unsuccessful, “_tsdns._tcp.tibia.run” DNS server returned answer with no data
07/04/2020 03:51:17 TSDNS Info A/AAAA DNS resolve unsuccessful, “lancheros.tibia.run” DNS server returned answer with no data
07/04/2020 03:51:17 TSDNS Info SRV DNS resolve successful, “_ts3._udp.lancheros.tibia.run” =(h: ts.tibia.run p:10504)
07/04/2020 03:51:19 TSDNS Info A/AAAA DNS resolve successful, “ts.tibia.run” =(h: 51.161.71.101 p:0)
07/04/2020 03:51:19 ClientUI Info Lookup finished: ip=51.161.71.101 port=10504 query=lancheros.tibia.run error=0
07/04/2020 03:51:19 ClientUI Info Resolve successful: 51.161.71.101:10504
07/04/2020 03:51:19 ClientUI Info Initiating connection: 51.161.71.101:10504
07/04/2020 03:51:19 ClientUI Info Connect status: Connecting
07/04/2020 03:51:19 TSDNS Info TSDNS queried unsuccessfully 198.27.104.48:41144
07/04/2020 03:51:19 TSDNS Info No TSDNS found
07/04/2020 03:51:19 PktHandler Devel Puzzle solve time: 0
07/04/2020 03:51:20 ClientUI Info Connect status: Connected
07/04/2020 03:51:20 ClientUI Info Connect status: Establishing connection
07/04/2020 03:51:20 ClientUI Info Connect status: Connection established
07/04/2020 03:52:03 PktHandler Info Cleaning up connection because of 12 resends of COMMAND packet
07/04/2020 03:52:03 PktHandler Info Dropping client 57 because of resend timeout
07/04/2020 03:52:03 ClientUI Info Connect status: Disconnected
07/04/2020 03:52:03 ClientUI Info Connection lost, want autoreconnect = 1
07/04/2020 03:52:04 ClientUI Info Autoreconnecting
07/04/2020 03:52:04 ClientUI Info Connect to server: lancheros.tibia.run
07/04/2020 03:52:04 ClientUI Info Trying to resolve lancheros.tibia.run
07/04/2020 03:52:04 TSDNS Info A/AAAA DNS resolve unsuccessful, “lancheros.tibia.run” DNS server returned answer with no data
07/04/2020 03:52:04 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “tibia.run” =(h: 198.27.104.48 p:0)
07/04/2020 03:52:04 TSDNS Info SRV DNS resolve unsuccessful, “_tsdns._tcp.tibia.run” DNS server returned answer with no data
07/04/2020 03:52:04 TSDNS Info SRV DNS resolve successful, “_ts3._udp.lancheros.tibia.run” =(h: ts.tibia.run p:10504)
07/04/2020 03:52:04 TSDNS Info A/AAAA DNS resolve successful, “ts.tibia.run” =(h: 51.161.71.101 p:0)
07/04/2020 03:52:04 ClientUI Info Lookup finished: ip=51.161.71.101 port=10504 query=lancheros.tibia.run error=0
07/04/2020 03:52:04 ClientUI Info Resolve successful: 51.161.71.101:10504
07/04/2020 03:52:04 ClientUI Info Initiating connection: 51.161.71.101:10504
07/04/2020 03:52:05 ClientUI Info Connect status: Connecting
07/04/2020 03:52:05 PktHandler Devel Puzzle solve time: 1
07/04/2020 03:52:05 ClientUI Info Connect status: Connected
07/04/2020 03:52:05 ClientUI Info Connect status: Establishing connection
07/04/2020 03:52:05 ClientUI Info Connect status: Connection established
07/04/2020 03:52:06 TSDNS Info TSDNS queried unsuccessfully 198.27.104.48:41144
07/04/2020 03:52:06 TSDNS Info No TSDNS found
07/04/2020 03:52:52 PktHandler Info Dropping client 98 because of ping timeout 19 0 0
07/04/2020 03:52:52 SCHandler Warning Got command data while disconnected, dropping
07/04/2020 03:52:52 ClientUI Info Connect status: Disconnected
07/04/2020 03:52:52 ClientUI Info Connection lost, want autoreconnect = 1
07/04/2020 03:52:53 ClientUI Info Autoreconnecting
07/04/2020 03:52:53 ClientUI Info Connect to server: lancheros.tibia.run
07/04/2020 03:52:53 ClientUI Info Trying to resolve lancheros.tibia.run
07/04/2020 03:52:53 TSDNS Info A/AAAA DNS resolve unsuccessful, “lancheros.tibia.run” DNS server returned answer with no data
07/04/2020 03:52:53 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “tibia.run” =(h: 198.27.104.48 p:0)
07/04/2020 03:52:53 TSDNS Info SRV DNS resolve unsuccessful, “_tsdns._tcp.tibia.run” DNS server returned answer with no data
07/04/2020 03:52:53 TSDNS Info SRV DNS resolve successful, “_ts3._udp.lancheros.tibia.run” =(h: ts.tibia.run p:10504)
07/04/2020 03:52:53 TSDNS Info A/AAAA DNS resolve successful, “ts.tibia.run” =(h: 51.161.71.101 p:0)
07/04/2020 03:52:53 ClientUI Info Lookup finished: ip=51.161.71.101 port=10504 query=lancheros.tibia.run error=0
07/04/2020 03:52:53 ClientUI Info Resolve successful: 51.161.71.101:10504
07/04/2020 03:52:53 ClientUI Info Initiating connection: 51.161.71.101:10504
07/04/2020 03:52:53 ClientUI Info Connect status: Connecting
07/04/2020 03:52:53 PktHandler Devel Puzzle solve time: 0
07/04/2020 03:52:54 ClientUI Info Connect status: Connected
07/04/2020 03:52:54 ClientUI Info Connect status: Establishing connection
07/04/2020 03:52:55 TSDNS Info TSDNS queried unsuccessfully 198.27.104.48:41144
07/04/2020 03:52:55 TSDNS Info No TSDNS found
07/04/2020 03:53:40 PktHandler Info Dropping client 57 because of ping timeout 19 0 0
07/04/2020 03:53:40 SCHandler Warning Got command data while disconnected, dropping
07/04/2020 03:53:40 ClientUI Info Connect status: Disconnected
07/04/2020 03:53:40 ClientUI Info Connection lost, want autoreconnect = 1
07/04/2020 03:53:41 ClientUI Info Autoreconnecting
07/04/2020 03:53:41 ClientUI Info Connect to server: lancheros.tibia.run
07/04/2020 03:53:41 ClientUI Info Trying to resolve lancheros.tibia.run
07/04/2020 03:53:41 TSDNS Info A/AAAA DNS resolve unsuccessful, “lancheros.tibia.run” DNS server returned answer with no data
07/04/2020 03:53:41 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “tibia.run” =(h: 198.27.104.48 p:0)
07/04/2020 03:53:41 TSDNS Info SRV DNS resolve unsuccessful, “_tsdns._tcp.tibia.run” DNS server returned answer with no data
07/04/2020 03:53:41 TSDNS Info SRV DNS resolve successful, “_ts3._udp.lancheros.tibia.run” =(h: ts.tibia.run p:10504)
07/04/2020 03:53:41 TSDNS Info A/AAAA DNS resolve successful, “ts.tibia.run” =(h: 51.161.71.101 p:0)
07/04/2020 03:53:41 ClientUI Info Lookup finished: ip=51.161.71.101 port=10504 query=lancheros.tibia.run error=0
07/04/2020 03:53:41 ClientUI Info Resolve successful: 51.161.71.101:10504
07/04/2020 03:53:41 ClientUI Info Initiating connection: 51.161.71.101:10504
07/04/2020 03:53:42 ClientUI Info Connect status: Connecting
07/04/2020 03:53:42 PktHandler Devel Puzzle solve time: 1
07/04/2020 03:53:42 ClientUI Info Connect status: Connected
07/04/2020 03:53:42 ClientUI Info Connect status: Establishing connection
07/04/2020 03:53:42 ClientUI Info Connect status: Connection established
07/04/2020 03:53:43 TSDNS Info TSDNS queried unsuccessfully 198.27.104.48:41144
07/04/2020 03:53:43 TSDNS Info No TSDNS found
