Since November 15th I encounter strange bug in new TS Client. When I connect to server, every time I’m getting put to server’s default channel and not the one I’ve set in bookmarks. In TS3 it doesn’t happen, but in TS5 it happens with every bookmark.
The day I discovered this bug I contacted via email with TS Support but since then I’ve seen no response whatsoever, which is kinda annoying.
The only thing I did since switching to TS5 was improving Security Level from 25 to 27 just for the sake of it. The thing is that I use the same identity on both TS3 and TS5 (in 5 bookmarks to be exact) and only in TS5 this bug happens.
It’s annoying that this is known for at least 2.5 months (since this is how long ago I contacted Support) and still it wasn’t patched or even (I think) described anywhere.
This is how it looks in my settings:
(some things were censored because they might contain personal information).
Try connecting to the server, switch to the desired channel, open the edit bookmark for the server (as in your screenshot), and then click the icon next to the default channel input field.
Disconnect and connect to the bookmark, see if you get put in the correct channel.
It was like that when I imported every setting from TS3. Even if I delete this backslash, it doesn’t help if anybody would like to ask that.
Edit: It’s like in UNIX when you have slash in filename or folder name, cause channel “channel.005.mp3” is in group “/public”. And yes, these are real channel names.
TS5 seems to have some problems with the slash in the channel name. I did some testing with a similar channel structure, and was able to reproduce the problem.
TS3 = Create Bookmark = Set Default Channel = Result: [spacer0]/\/public/channel.005.mp3
TS5 = Use Bookmark = Result: Landing in Root channel
TS5 = Connect to correct channel = Edit Bookmark = Set Default Channel = Result: [spacer0]//public/channel.005.mp3
TS5 = Use Bookmark = Result: Landing in [spacer0]
I doubt very much that an improvement in the Security level had anything to do with the broken bookmark. I’d say that something was changed within the code of TS5 that introduced a different behaviour, but that is well beyond my scope. @TS_Chris
Yes, this doesn’t sound right but it is like I’m saying And this is the funniest thing.
Just for clarity:
beta.12 - works fine
beta.13 through beta.15 - still fine (but if I remember correctly, I missed these versions and went straight to beta.16, even if I was checking for updates at least once a day)
beta.16 - still fine
beta.16 after improving SL - well, crap… no longer works
today - still does not work properly
Maybe it will be fixed in a future update, I’ll wait, I have plenty of time. The only thing is that it’s somewhat inconvenient.
But thanks for your help Brady.
My Channel name is this one: [cspacer]● AFK/Anderer TS/Beschäftig ●
I set this channel to default join channel, but when I join I only land in the Default Channel of the Server. I think it has to do with the ‘/’ or caracter in the channel-name
TS3 saves the channel ID when the default channel was set when connected to the server and you are in the channel.
TS5 only uses the name (downgrade), so when the channel gets renamed (for example because it hast a date/time stamp in the name), you will get thrown in the default server channel instead.
I found a solution for this bug.
All you have to do is enter the server, disconnect from it and then connect again, then it sends you to the channel you set. However, I would ask to correct this bug.
