moved by moderator
Hello, I am an iOS TS user and every time I try to asign a Tilde (~) or (Tab) key for Push to Talk TS crashes. I am curious if this is a known issue and what might fix this?
Thanks in advance.
Thanks in advance.
The next Beta update for TS5 (no release date yet).
Hello, Same thing with my M1 Air with the latest version. Is there really no other way to solve this other than waiting for an update? Can I use an older version of teamspeak for the time being?
When it was said what to do, why you expect anything else to be the fix?
You got option but no fix:
So, I’ve tried several times to get push to talk on MacBook, and I get an error EVERY time. The photo shows the error, but I’m at a loss. Please help. Edit: on a m1 Apple chip, might need intel.
I’ll use a third-party program until a update comes out.
Have the same problem. MacOS 14.4.1, TS CLIENT 64-BIT 5.0.0-beta77. Still not fixed?
Can I use somehow workaround to set PTT button? Probably edit some XML file or something like this?
That’s the case for beta 77
Unfortunately no.
Mac user here, I did figure out a work around but it is dumb and requires a non-mac computer to set up a bind.
This is because binds appear to be shared via account auth to my macbook.
Like OP, I can’t set a hotkey. But I can use the one i set on my non-macbook for my macbook. In this case, its mouse 5.
But I don’t use a mouse with my macbook. So I used Karabiner Elements to emulate that key.
Below is an example of that. I just mapped the bottom left key to mouse5.
This allows me to press the push to talk without mapping it. Frankly, I can’t imagine using any voip without push to talk – it’s like eating cereal without a spoon.
Hope this helps someone.
Tested this on the latest version of Teamspeak 5 using an Apple silicone Mac and this is no longer crashing. Hope that this is the same for anyone with an Intel Mac.
