Hi there,
I’ve an issue per the subject line. I’ve read older threads to so avail.
Not running ASUS or any overclocking utilities.
PC is a MSI Nightblade MI2C-063UK, Windows 10 64bit, Intel® HD Graphics 530/NVIDIA GeForce GTX 960 GPU
Here are the contents of the log (they don’t appear to be saved to file) up to the point of freeze.
01/07/2020 16:28:09 Info TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
01/07/2020 16:28:09 Info SystemInformation: Windows 10 (18362) x64 (AMD or Intel) Binary: 64bit
01/07/2020 16:28:09 Info Using hardware aes
01/07/2020 16:28:09 Direct Sound Debug setting timer resolution to 1ms -
01/07/2020 16:28:10 Info *** Time [SPAWN_EVENTCONVERTER]: 257
01/07/2020 16:28:10 ClientUI Info OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (NVIDIA GeForce GTX 960 Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.0.57ea533f79a7)
01/07/2020 16:28:10 RevocationListCache Error Failed to import revocation list from cache
01/07/2020 16:28:10 Info successfully downloaded revocation list for accounting
01/07/2020 16:28:10 Info *** Time [ICONMANGER]: 132
01/07/2020 16:28:10 Addons Info Checking for addon updates…
01/07/2020 16:28:10 Plugins Info Loading plugin: clientquery_plugin_win64.dll
01/07/2020 16:28:10 Query Info listening on 127.0.0.1:25639
01/07/2020 16:28:10 Plugins Info Loading plugin: gamepad_joystick_win64.dll
01/07/2020 16:28:10 Gamepad Plugin Info Found client raw input wnd proc
01/07/2020 16:28:10 Gamepad Plugin Info Cleared device list
01/07/2020 16:28:10 Gamepad Plugin Info Found device \?\HID#VID_045E&PID_02FF&IG_00#7&2E196F3F&1&0000#{4D1E55B2-F16F-11CF-88CB-001111000030}
01/07/2020 16:28:10 Gamepad Plugin Info Found device \?\HID#VID_B58E&PID_9E84&MI_03&COL02#7&36C589D8&0&0001#{4D1E55B2-F16F-11CF-88CB-001111000030}
01/07/2020 16:28:10 Plugins Info Loading plugin: teamspeak_control_plugin_win64.dll
01/07/2020 16:28:10 ControlPlugin Info Control Plugin started, accepting connections
01/07/2020 16:28:10 Overwolf Debug Detected Overwolf start
01/07/2020 16:28:10 Addon Info Addon up to date.
01/07/2020 16:28:10 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
01/07/2020 16:28:10 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
01/07/2020 16:28:11 Info successfully downloaded revocation list for myteamspeak id
01/07/2020 16:28:11 Info *** Time [BUILD_GUI]: 386
01/07/2020 16:28:11 Info *** Time [SERVERVIEW]: 419
01/07/2020 16:28:11 Info *** Time [SERVERVIEWMANAGER]: 528
01/07/2020 16:28:11 Info *** Time [MAINWINDOW]: 1627
01/07/2020 16:28:11 Info *** Time [INIT]: 1627
01/07/2020 16:28:11 ClientUI Info Qt version: 5.12.3
01/07/2020 16:28:11 ClientUI Info Using configuration location: C:\Users\David\AppData\Roaming\TS3Client\settings.db
01/07/2020 16:28:12 Bookmarks Info Collecting autoconnect bookmarks
01/07/2020 16:28:12 ClientUI Info Last update check was: Wed Jul 1 14:42:38 2020
01/07/2020 16:28:12 Info Statistics report: Not yet, next report on Mon Jul 6 14:47:55 2020
01/07/2020 16:28:12 Newsticker Info Newsticker next check: Thu Jul 2 13:42:38 2020 GMT
Any help would be appreciate.
Thanks.
