TS client crashes on MacOS when connecting
Having the same issue! Exactly same error behavior
I’m glad I am not alone. Thanks for replying!
ah look here, there’s even a beta version available: TS client crashes on MacOS when connecting - #8 by LoneStarGazer
Had the same issue on 11.3. The new beta 3.5.7 resolved the issue!
Thank you!
I updated my Apple on 4/26/2021 with the BigSur update and now I get this error message.
Grab yourself this client
http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/
Just installed it and it still doesn’t work, I am running BigSur 11.3, the update for Apple was on 4/26/2021
I figured it out, I had to allow it to open, I just looked at all the security screens. Thank you for the help.
macOS 11.3
TS 3.5.6
Updated macOS the other night an TS auto-closes when attempting to connect to a server
Please show us a Client Log. :slight_smile:
Maybe the new Beta Version could fix this: Index
Also, the beta version worked
Thanks :slight_smile:
Glad to hear, that its now solved. :slight_smile:
Welcome to TeamSpeak :slight_smile:
Hello everyone,
I got the problem that my Teamspeak 3 client crashes as soon as I try to get a connection. It always worked. I also tried to completely (also deleted all the leaved data inside library) remove teamspeak data and reinstalled but the problem is still there. I would be glad if someone could help me with that.
Regards
tet
Hello @tetsuo101
Please open path Library/Application Support/TeamSpeak 3/crashdumps on your Hard drive and attach at least the crash file.
And what you could try is to update the Client to this Beta Version: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg maybe this fixed your Crash
thanks a lot Rikku. I just installed the beta client and everything works fine as before. thanks a lot for your quick response.
Welcome to TeamSpeak.
Feel free to ask us all here, if you have any other Problems. :slight_smile:
Just signed up to the forum…having the exact same problem.
Ah, never mind…just saw the beta client info
just wanted to say I followed the advice from Rikku and now everything works fine thanks a lot again :wink:
