TS doesn't open when using Windhawk
After updating from beta2 to beta3 Teamspeak just doesn’t open at all just windows loading wheel for 3 seconds and nothing…
Reinstalling / Repearing doesn’t work, running by admin or changing comptability doesn’t work either.
Accidentally found a fix on announcement page, the problem was with Windhawk.
Windhawk conflict causing crashes
To fix this, open Windhawk’s advanced settings and add TeamSpeak.exe to the Process exceptions list. Thanks to @Ominouscold for identifying this workaround!
How do I do it? I have the same error. I tried the solution but couldn’t do it.
Go to Windhawk > Settings > Advanced settings > “More advanced settings” on the bottom > Find Process exclusion list > Go to your Teamspeak directory > right click on TeamSpeak.exe and Copy as path > and put it into Process exclusion list.
I did all of them but it won’t open.
livesaver! many thx!
