I have two capture profiles and switch between them with hotkeys:
Default: laptop mic, Push-To-Talk (the laptop mic has no noise isolation).
Headset: headset mic, Voice Activity Detection (the headset isolates background noise well).
If I press the Headset hotkey while the headset is disconnected, TS3 doesn’t fall back to the Default profile. It stays on the Headset profile and overwrites its capture device with the system default, which is the laptop mic. This causes two problems:
The Headset profile has to be manually fixed by re-selecting the headset device.
The laptop mic is now running under voice activation, so it transmits any ambient noise, defeating the purpose of this setup
Falling back to a default capture profile would make sense. Instead, TS3 overwrites the device on the selected capture profile with the default device, requiring a manual fix to correct it.
Is there a reason for this behavior, and are there any workarounds? For example, a way to lock the selected device within a capture profile?
