TS3 ID could not be validated
pastebin of client log
Screenshot_1
I’ve tried reinstalling TS3 and relogging in. None of those worked alongside any of the solutions on the forum.
You can’t reach the services (check your client log) or you did reset your password and did not enter a recovery key.
You are logged in but the service for sync mytsid etc can not be reached or is not started.
Then check that server can reach the myTeamSpeak services
https://support.teamspeak.com/hc/en-us/articles/360002712257-Which-ports-does-the-TeamSpeak-3-server-use- 10
Make sure your login in client is still valid and that you get no errors about the myTSID in your client log.
