After update, my server won’t turn on. I can only see this
No server running (ts3server.pid is missing)
ts@xxx:~/teamspeak3-server_linux_amd64$
I deleted the file to create it again, but it doesn’t help
Anything in your log files?
Also what command are you starting the server with?
Only this in log:
2020-01-31 19:20:02.105612|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.9.1 (2019-07-02 13:17:23)
2020-01-31 19:20:02.105811|INFO |ServerLibPriv | |SystemInformation: Linux 3.14.32-xxxx-grs-ipv6-64 #9 SMP Thu Oct 20 14:53:52 CEST 2016 x86_64 Binary: 64bit
2020-01-31 19:20:02.105834|INFO |ServerLibPriv | |Using hardware aes
2020-01-31 19:20:02.108154|INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, ©TeamSpeak Systems GmbH
2020-01-31 19:20:02.108175|INFO |DatabaseQuery | |dbPlugin version: 3.11.1
2020-01-31 19:20:02.109778|INFO |DatabaseQuery | |checking database integrity (may take a while)
2020-01-31 19:20:02.136230|ERROR |DatabaseQuery | |sqlite3_prepare failed no such table: revocations
2020-01-31 19:20:02.136265|ERROR |DatabaseQuery | |db_open() SELECT revocation_key, revocation_expiration FROM revocations WHERE re error: no such table: revocations
2020-01-31 19:20:02.136280|INFO |ServerLibPriv | |failed to load revocation list from cache: 1280
2020-01-31 19:20:02.140565|ERROR |DatabaseQuery | |sqlite3_prepare failed no such table: revocations
2020-01-31 19:20:02.140586|ERROR |DatabaseQuery | |db_open() SELECT revocation_key, revocation_expiration FROM revocations WHERE re error: no such table: revocations
2020-01-31 19:20:02.140600|INFO |ServerLibPriv | |failed to load revocation list from cache: 1280
2020-01-31 19:20:02.145038|WARNING |Accounting | |Unable to open licensekey.dat, falling back to limited functionality
2020-01-31 19:20:02.145258|CRITICAL|Accounting | |Failed loading default license file!
What TS Server version did you update from and which did you install?
You might have to try renaming ts3server.sqlitedb and start from scratch.
Did you unpack all the server files when you upgraded?
ts@wiejska-chata:~/teamspeak3-server_linux_amd64$ ./ts3server_startscript.sh start
ts3server.pid found, but no server running. Possibly your previously started server crashed
Please view the logfile for details.
Starting the TeamSpeak 3 server
ts3server is not executable, trying to set it
./ts3server_startscript.sh: line 9: 19354 Segmentation fault “./${BINARYNAME}” “${@}” “daemon=1” “pid_file=$PID_FILE”
TeamSpeak 3 server could not start
now?
Looks like your permissions are wrong - did you unpack it as your ts user? You might just need to do a chown/chmod on it - show us the output of ls -al
in that folder
I used chown/chmod and still not working, again "/ts3server_startscript.sh: line 9: 19354 Segmentation fault “./${BINARYNAME}” “${@}” “daemon=1”
