TS5 Temp channels
hi am using the beta and i cant create temp channels even though I have the correct permissions at the server is it a bugg or has it something to do with my stuff?
Probably something on your side my friend.
From the beta client i just created a temporary channel both on my own server and on the beta new server.
sounds like permission problem, i dont think this is a bug
try to create temp channel with ts3 client if it work then its a ts5 client problem or if it not work check your server groups permissions
i can create channel with ts 3 but not with ts5 I don’t get why
do you connect with the same identity in both clients?
Yes I log in with same identity at least I think so but if I log in with other identity I still have same perms on the server
