I have a recurring issue with TeamSpeak 6 on Windows where the TeamSpeak window suddenly stops accepting mouse clicks.
The window is still visible and responsive, but clicking anywhere inside the TeamSpeak client goes straight through the window and clicks the application behind it instead.
The title bar itself still works, so I can move the TeamSpeak window normally.
What I already tested
Reinstalled TeamSpeak completely
Started TeamSpeak with:
--disable-gpu --disable-gpu-compositing
The parameters were confirmed to be active, but the issue still occurred.
Alt+Tab away and back → does not fix it
Win + Ctrl + Shift + Bto reset the Windows graphics driver → does not fix it -
TeamSpeak process still reports
Responding = True
Investigation
While the issue was active, I checked which window Windows detected underneath the mouse cursor.
With the mouse visibly positioned over the TeamSpeak client area, WindowFromPoint() returned the Chrome window behind TeamSpeak instead of TeamSpeak.
The TeamSpeak main window had the following extended window style:
ExtendedStyleHex : 0x280120
WS_EX_TRANSPARENT : True
WS_EX_LAYERED : True
WS_EX_NOACTIVATE : False
The window itself still returned:
WM_NCHITTEST = HTCLIENT
I then manually removed only the WS_EX_TRANSPARENT flag from the TeamSpeak main HWND using SetWindowLongPtr.
Before:
0x280120
WS_EX_TRANSPARENT = True
After:
0x280100
WS_EX_TRANSPARENT = False
Immediately after removing WS_EX_TRANSPARENT, TeamSpeak became fully clickable again without restarting the client.
So the actual click-through behavior appears to be caused by the TeamSpeak main window having WS_EX_TRANSPARENT set while also using WS_EX_LAYERED.
Important detail
I do not know yet whether TeamSpeak itself is setting WS_EX_TRANSPARENT, or whether another application/overlay could somehow be modifying the window style.
However, removing that flag immediately fixes the issue every time I have tested it.
Reproduction
Unfortunately I do not have reliable reproduction steps yet.
The problem happens randomly after TeamSpeak has been running for some time.
Environment
Windows
TeamSpeak 6
Issue also occurs with GPU acceleration disabled using:
--disable-gpu -
If useful, I can provide the PowerShell scripts I used to inspect the HWND, window styles and remove the WS_EX_TRANSPARENT flag while the bug was active.
