bro i created an account just to comment, cause this overlay is ■■■■■ perfect for me, really
it has everything i need, the name of the user, an indicator when is input or output is muted. the way to lock on screen is so smart i got delighted, i found so sweet that you created a menu to control what appers and the size of it, i need to congratule you, buddy.
A just have one quick observation, its nothing that bothers me, i just want you to know, the icons for input and output muted are little broken, idk
the afk is alright, but the other two doenst look like and mic and a headphone, how i sad, its no problem for me, cause i just use the color to know
anyway, congrats again, buddy
Hey Beka2nt,
I’ve been pretty busy atm, so sorry for the late reply. The program works great overall, but I have to re‑enable the lock (click-through) feature manually every time I start it. The config files are being written correctly to AppData.
My installation:
Installation Path: C:\Program Files\TeamSpeak Overlay
Config Path: C:\Users\tommy\AppData\Roaming\TS6-SpeakerOverlay ( comes with two files config.json/apikey.txt )
OS: Win11
TS Overlay: Release v1.4.3 i use
I like this tool! You don’t have to fix this for me — I’m fine with it as is!
Thanks for the work you put into this.
Hello, can you give the plug-in a function to display text messages? Some of my friends can’t speak for some reason
